Results 1 to 10 of 10
- 01-01-2013, 04:52 PM
Thread Author #1
how to Droid DNA Disk Drive mode??
Hey can anybody helpme out ihave been trying to transfer music from my computer to my phone but i havnt been able to. I have called and emailed HTC and got different answers both ways but neither way has seemed to work. I have been told to disable the "USB Debugging" option and restart the phone then plug it in and select disk drive mode. I never got a screen to select the connection type.
Sent from my HTC6435LVW using Android Central Forums - 01-01-2013, 04:56 PM #2
Re: how to Droid DNA Disk Drive mode??
Pc or Mac? I try installing the correct drivers. If you have a mac, download aft(android file transfer)
Sent from my HTC6435LVW using Android Central ForumsPrivacy is overrated :P - 01-01-2013, 05:15 PM
Thread Author #3
- 01-01-2013, 06:00 PM #4
install the HTC Sync that will show up as a drive on your phone after you plug it in. Don't use Sync, but installing it will install the drivers.
Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig. - 01-01-2013, 07:56 PM
Thread Author #5
- 01-01-2013, 07:57 PM
Thread Author #6
And Email 3
Thank you very much for taking the time to contact HTC Technical Support. I appreciate your interest in connecting your DROID DNA into Disk Drive mode, Austin, and I will gladly provide assistance.
In Sense 4+, used on the DROID DNA, the Connect to PC screen is more intuitive then previous versions. In Sense 4+, the selection UI pop up after connecting to PC is no longer necessary. All features - charging, syncing, disk drive and Smart Network Sharing are already on and running.
Sent from my HTC6435LVW using Android Central Forums - 01-01-2013, 08:53 PM #7
- 01-02-2013, 07:56 AM #8
Using Windows 7 or 8, you need only install HTC Sync (get the latest version from HTC Support), Install and reboot your computer, I personally keep USB Debugging turned on, Here you will see that there are 2 mounts when the phone is connected .. Partition I - HTC SYNC MGR and PORTABLE Device showing hte Phone Storage, click in there to navigate to your desired folder.
- 03-13-2013, 04:12 PM #9
I use a third party application that needs the Android phone mounted as a removable storage for the sync. I can see that the DNA is accessbile as Portable Devices, but for some reason this is not recognized, which I think it the reason I mentioned above.
Is there a workaround?
Thanks, - 05-17-2013, 08:42 AM #10
I wanted to add that I'm having the same problems. When I connect the Droid DNA, HTC Sense says there's no device detected. I downloaded the latest from the site for my laptop (running Windows 7 Home Premium).
Another problem: I turn off "USB debugging", but it comes on again as soon as the phone is connected; nothing turns this off permanently.
When I do uncheck it and go to select the USB connection mode, I don't get a selection for Disk Drive. I get (under USB: USB network setting):
- None
- Smart network sharing
- Internet Connection Mode
- Internet pass-through
Also on my phone: HTC Sync is not listed when I go into all Apps, but when I select Manage Apps, it shows two: HTC Mobile Sync and HTC Sync.
Any ideas?
Why is connecting in Charge Only mode acting like Disk Drive mode
By pagerond in forum Verizon HTC ThunderboltReplies: 0Last Post: 06-30-2011, 11:09 AM -
Automated Disk Drive Mode
By ill in forum HTC EVO 4GReplies: 2Last Post: 02-27-2011, 06:38 PM -
How to Set ZTE V880 Brush Mode
By ledde in forum Misc. Android Phone ChatReplies: 0Last Post: 02-17-2011, 08:39 PM -
DInc crashes PC in disk drive mode
By jaharris67 in forum Verizon Droid IncredibleReplies: 5Last Post: 10-26-2010, 09:02 PM -
How to see Internal memory drive's usage?
By biggamer3 in forum HTC EVO 4GReplies: 2Last Post: 06-14-2010, 01:05 PM
Reply
