- 01-06-2013, 05:51 PM
Thread Author #1
Night Mode (Controlling LED Touch Buttons)
Would someone please help this old man out and guide me in lowering and/or turning off the three LED touch buttons at the bottom of my DNA screen. I am a night time reader (using Calibre Companion with paid version of Aldiko Reader) and these three LEDs are burning my eyes out. I have tried the following screen dimmer apps with no luck: Night Mode and Screen Dimmer. I appreciate anyone's help on this and I do realize that I may be missing a completely apparent setting that does this.
- 01-06-2013, 08:00 PM #2
Re: Night Mode (Controlling LED Touch Buttons)
Unless you're rooted, you can't. Sorry
I've had the same complaint for years since the original HTC Evo.
Edit: Never mind, apparently I hadn't checked on this recently enough=/Last edited by mtmjr90; 01-06-2013 at 10:27 PM.
- 01-06-2013, 08:01 PM #3
I got tired of the same thing myself. Last night I downloaded "Screen Filter" and it worked like a charm.
It allows you to change brightness and disable the soft key lights. In app adjust brightness, make sure Enable soft-key backlight is not selected, finally hit Enable Screen Filter.
The last trick is to press the power button once to turn off the screen, press again and the screen will come back but the Backlight keys will stay dark. - 01-06-2013, 08:19 PM
Thread Author #4
- 01-06-2013, 10:26 PM #5
- 01-07-2013, 08:15 PM
Thread Author #6
- 01-10-2013, 01:45 PM #7
Screen Filter is fabulous, I recommend downloading Power Toggles to keep it in your notifications tray at all times--that way you don't have to exit to the app tray to launch, just pull down the notifications tab and you're all set.
Bear in mind Screen Filter does a couple wonky things to your device. Nothing terrible, but you can't say, download apps with the filter activated. I had this on my Nexus 7 and for the longest time I couldn't figure out what was wrong. Had to randomly stumble upon user comments on the app (they've since announced it on the app description itself).
Issues with touch buttons below the screen?
By trojandrew in forum Samsung InterceptReplies: 6Last Post: 03-24-2011, 03:03 PM -
Multi-media night mode
By elir41 in forum Motorola Droid XReplies: 0Last Post: 09-14-2010, 03:08 PM -
Touch Button Responsiveness Issue? Not mentioned on other reviews....?
By showmrock in forum Sprint Epic 4GReplies: 15Last Post: 08-18-2010, 12:53 AM -
Touch buttons on bottom stay light?
By nm08srt8#ac in forum HTC EVO 4GReplies: 12Last Post: 07-01-2010, 07:51 PM -
Touch Buttons
By Your my boy blue in forum Verizon FascinateReplies: 3Last Post: 07-01-2010, 02:42 PM
Reply
