Results 1 to 3 of 3
- 01-10-2013, 07:45 AM
Thread Author #1
Voltage and Current?
Greetings all.
I did a forum search and couldn't find an answer to my question so here goes:
Anyone know what the voltage and current is for the Droid DNA? I bought an Anker Astro 5600 portable battery to use to charge up the phone and it's not working correctly. It only charges the phone for 30-40 seconds then stops. I used both the cable supplied by Anker and also the one that came with my phone. Neither work. Anker is requesting that I provide them with the voltage and current information so they may see if it's compatible.
Thanks! - 01-10-2013, 08:17 AM #2
Re: Voltage and Current?
I have the same anker unit and it works fine. May be you got a defective unit. Did you charge the Anker up first for that all four blue lights lit up and then went dark after the unit was fully charged? The Anker charged my DNA without a hitch recently on a plane. It's a bit slower than an AC charge, but it works fine.
- 01-10-2013, 08:42 AM
Thread Author #3
flashing roms and current settings
By feq451 in forum HTC Evo Shift 4G Rooting, ROMs, and HacksReplies: 9Last Post: 04-03-2011, 12:20 PM -
Rooted, flashed CWM with Odin, and then installed Rom Manager and currently stuck...
By som3on3_10 in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 22Last Post: 03-04-2011, 11:34 PM -
Peak battery voltages and peak percentages
By skiddingus in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 3Last Post: 02-21-2011, 11:16 AM -
Power Usage App. Voltage and Current
By IAmSixNine in forum Android ApplicationsReplies: 1Last Post: 12-01-2010, 10:38 AM -
icon-style widget for weather? and current date?
By bennish in forum Android ApplicationsReplies: 5Last Post: 06-17-2010, 02:07 PM
Reply
