Results 1 to 9 of 9
    Default Battery Life...
    Is nothing to sneeze at Man I love this phone; after setting up Nova prime, at 60% after over 9 hours...surfing, txt, email, calls, playing with this thing all day...awesome!
    Attached Thumbnails Attached Thumbnails Battery Life...-2013-01-11_15-01-56.jpg
    Thanked by:
  2. #2
    Default Re: Battery Life...
    Ive just got my note 2 and im also in love with thw battery life :-)
    Sent from my GT-N7100 using Android Central Forums
    Attached Thumbnails Attached Thumbnails Battery Life...-uploadfromtaptalk1357935434102.jpg
    awesome!! I did like the Note II when I demoed it....like it way better than the Galaxy S3.....just a tad too big though, the DNA was the perfect trade off for size
  4. #4
    Its my first androd so im not sure what yours is? I came from an iphone 4s. The note 2 is big but im just about getting used to it. I love it
  5. #5
    My battery life is terrible. Always charge all night and always on yellow by 7 pm. I'm not a heavy email user, mostly play Draw Something and add to my food diary on My Fitness Pal. And I'm on wifi all day. What can I check to make it last longer?
    Sherri
  6. #6
    What phone?
  7. #7
    revtech's Avatar
    Posts
    Global Posts
    601 Global Posts
    Quote Originally Posted by Andyvalver View Post
    What phone?
    Since the op chose to post in a verizon droid dna forum that should probably give you a clue
  8. #8
    Draw Something is a notorious battery hog. Probably your problem there.
    I'd recommend you try GSam Battery Monitor from the app store. It doesn't save battery life, but it lets you track which apps/processes are using the battery up. You might find something that you can remedy.
  9. #9
    Irvgotti's Avatar
    Posts
    ROM
    Stock Sense 4.1.1
    Quote Originally Posted by revtech View Post
    Someone did post about the note 2. ^_^
    Sent from my HTC6435LVW using Android Central Forums
    Privacy is overrated :P
    Thanked by:
  1. Battery life terrible?
    By bilobi in forum T-Mobile G1
    Last Post: 04-02-2013, 01:48 PM
  2. Samsung Moment battery life
    By IIJBII in forum Samsung Moment
    Last Post: 03-21-2012, 08:48 PM
  3. Improving Battery Life on Your Android Device
    By ERDude in forum HTC Hero
    Last Post: 02-04-2010, 12:33 PM
  4. battery life
    By kunak83 in forum Motorola Droid
    Last Post: 11-29-2009, 11:28 AM
  5. Anyone's Battery Life Getting BETTER?
    By Christopher in forum Motorola Droid
    Last Post: 11-20-2009, 11:04 PM
