Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Default Re: Who's having issues with their DNA?
    The SIM card error just happened to me this morning. I just removed and reinstalled the sim and it hasn't happened since.
    Sent From My HTC Droid DNA
  2. #27
    Default
    Quote Originally Posted by nDroid3 View Post
    Having issues with the wallpaper scroll function with Nova Launcher. For some reason, the wall paper stopped scrolling when swiping to different home screens.
    I've read in other threads this is a limitation from HTC. Luckily Nova has a workaround that I've found works: Nova settings > Desktop > Wallpaper Scrolling > Force. Should work like a charm
  3. #28
    I've had mine for 2 months now and can honestly say I've had zero problems that I can think of. Battery life has been great, way better than I expected, and I've probably only rebooted the phone once or twice. There was an issue with battery drainage due to location settings in Latitude which was easily fixed. Slacker works fine for me.
  4. #29
    This is like a therapy session for DNA owners, love this thread. I've had the.....
    1. non focusing video recorder problem (not aware of a fix and hope an update is published soon).
    2. recently the SIM card problem (seemingly easy fix with pop out and reinsert).
    3. horrible Bluetooth quality on both headsets and hands-free link vehicle connection. Connections ocurr but voice quality is unusable for business conversations (not aware of a fix here either, so hopefully a software update will fix).
    4. Odd camera problem has ocurred a few times where I was in camera app, hit the switch-app button (lower right hot key on DNA) in attempt to switch to another running app, and screen went blank. Couldn't shut down phone. Haptic buttons still functional but couldn't see screen. Left it alone and screen eventually came back up. Very odd.
    5. And more of a complaint than a problem: the keyboard sucks imo. Back to swiftkey perhaps.
  5. Thread Author  Thread Author    #30
    Quote Originally Posted by blashandroid View Post
    Yeah i dont like the keyboard too much
    Sent from my HTC6435LVW using Android Central Forums
  6. #31
    Has anybody been able to play music through the htc music app? I added files to the music and media folder but its not finding my mp3 files. Also did a reboot.
  7. #32
    i plugged in headphones during a phone cal and the call would get disconnected after a few seconds. once i unplugged, stopped happening.
    also, i dunno if this is because of my diztronic case, but whenever im on the phone, the person on the other end says it seems like im really far away. i guess my voice doesn't like to travel to that little hole on the bottom of the phone.
  8. Thread Author  Thread Author    #33
    Quote Originally Posted by redman213 View Post
    Working fine for me. Have something like 600 songs. Try using HTC sync manager for your music. After you install it on your computer itll auto load your music into it. Plug in your phone and go to sync settings and tell it to add music to your phone.
  9. #34
    The only big problem I'm having is with the Mobile Hotspot / Tethering
    While tethered to my iPad or iPod the LTE is very slow to not existent, LTE works fine on the phone itself, but my iPad for some reason has problem staying connected. It will show the Wifi icon, and my phone will show that the iPad is tethered, but when I'm using the browser it just sits and hourglasses, while the DNA shows no data movement.
    I was about to get the phone replaced, when I read on DroidLife that this is known issue with the DNA and the native Verizon Tethering App. Hope they fix it soon.
  10. #35
    Well i tried two files but the sync manager i will try.
  1. Just in general, is anyone having any issues with their sgs3?
    By intoaction66 in forum T-Mobile Galaxy S3
    Last Post: 03-01-2013, 10:36 PM
  2. Who is going "bareback" with their DNA??
    By kilofox in forum Verizon Droid DNA
    Last Post: 02-15-2013, 09:38 PM
  3. Replies: 5
    Last Post: 12-11-2012, 04:21 PM
  4. Replies: 42
    Last Post: 12-06-2012, 08:26 PM
  5. Anyone having these issues with their DInc2?
    By yochino in forum Verizon Droid Incredible 2
    Last Post: 05-30-2011, 09:36 PM
B
