Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By PsychDoc
    Default How Many Of You Are Using An After Market Launcher?...
    After reading rave after rave about Nova Launcher I decided to take the plunge. I'm not very techy so I had some fears that I would be overwhelmed by all the complexity but I have to say the process of switching over was pretty painless. And now I can see what everyone is raving about. The degree of flexibility and customization is amazing. The changes are not revolutionary, mind you, but it's great to have additional flexibility regarding appearance and icon/app/widget behavior.
    Any of you opting for an after market launcher go for anything other than Nova?
    If so, why?
    ten20life likes this.
  2. #2
    Default Re: How Many Of You Are Using An After Market Launcher?...
    I'm using tsf shell. Expensive but very cool. Looks like next launcher by go is similar.
  3. #3
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,226 Global Posts
    ROM
    NOS M7 Sense 5.0
    I switch between Sense and Nova every week or so just for a change.
  4. #4
    liquid29's Avatar
    Posts
    Global Posts
    14 Global Posts
    I'm currently using Holo. I was on Apex, but it crashed all the time, and Nova seemed to struggle quite a bit too, so ultimately Holo won by being able to run solidly.
  5. #5
    Nova. No problems at all, though curious to try Holo and TSF Shell.
  6. #6
    ADW here, Can modify number of columns/rows, has transparency and reflections, used with multi live wallpaper and Amazing text I get a lot of comments on the design.. how'd u do that it's pretty cool... sorry I'm 'senseless' (or at least up front it's always running)
  7. #7
    Upstreammiami's Avatar
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    For me it's stock or nova
    Sent from my HTC6435LVW using Tapatalk 2
    I'm the ROOT man
    G Talk: Upstreammiami3o5
    Let me help you ROOT your phone
  8. #8
    nDroid3's Avatar
    Posts
    Global Posts
    73 Global Posts
    Nova for me...sometimes I like to use stock sense.
  9. #9
    Nova Launcher + Widget Locker, to imitate raw 4.1 . Nothing wrong with sense, but I'm not a fan of that little pull ring.
  10. #10
    Mooem's Avatar
    Posts
    ROM
    CM10
    It's Nova launcher for me. I tried the Sense launcher for all but five minutes before I decided I wanted to customize my home screen to a much greater degree than what stock Sense offered. I've also pretty much disabled the lock screen since everything I need to access is on my primary home screen anyway.
  11. #11
    Lactose The Intolerant's Avatar
    Posts
    ROM
    Stock until 4.0.4 hits
    Moved from ADW EX to Apex to Nova Prime. Not leaving Nova Prime any time soon.
  12. Thread Author  Thread Author    #12
    Quote Originally Posted by Lactose The Intolerant View Post
    What does Nova Prime add that the free version cannot do?
  13. #13
    Posts
    ROM
    Quote Originally Posted by PsychDoc View Post
    Nova Launcher Prime unlocks the following features in Nova Launcher:
    Drawer Groups:
    Folders in App Drawer
    Unlimited custom tabs
    Organize apps into tabs and folders in the app drawer
    Gestures
    Quickly start Nova Actions or Apps from gestures on the desktop, such as pinching, swiping or two-finger swiping.
    Hide Apps
    Keep a clutter free drawer by hidding never used apps.
    Dock Swipes
    Get more use out of your dock apps by setting swipe-actions
    Unread Counts
    Never miss an email. Unread count badges for SMS, Missed calls, Gmail, Email, Google Voice and more. Counts show in the dock, desktop, drawer and folders.
    More Scroll Effects
    Permissions:
    Access Widget Data: This is in order to display the widget and widget's data to you. This dialog/permission is new in Jellybean. The data is not used for anything aside from displaying it.
    Internet/Network State/Wifi State: Optional & Anonymous error/usage reporting. Download of opt-in Beta updates.
    Directly call phone numbers: Only used if you place a direct-dial shortcut on the homescreen.
    Wallpaper/Vibrate/Status Bar/Choose Widgets: Standard Launcher functions
    USB (SD) Storage: Backup/restore and beta updates
    Retrieve Running Apps: Used by Aggressive Desktop setting and to warn in settings when multiple launchers are running in history.
  14. #14
    Nova Launcher Prime. I switched from Apex to Nova, much quicker and snappier. The ability to scroll through the dock is nice too.
  15. #15
    apex lets you do half of what nova prime does like hide apps in the drawer, gestures
  16. #16
    jfoofoo's Avatar
    Posts
    Global Posts
    299 Global Posts
    +1 on nova
  17. #17
    I have nova, bought it during Play Store sale for like 50cents or something, but it bugs me that the folder icons are slightly bigger than the app icons.... Plus I like Android Music Player and you can't use it without Sense...... So, I don't really use it..
  1. Replies: 157
    Last Post: 11-16-2010, 08:59 AM
  2. How many of you guys use a case with your DINC?
    By drumzalicious in forum Incredible Accessories
    Last Post: 10-30-2010, 04:49 PM
  3. How many of you are bleeding edge gadget (cellphone?) fans?
    By duckwars in forum The Android Central Lounge
    Last Post: 06-02-2010, 07:00 PM
  4. So, how many of you are playing with Google Wave?
    By pbrennan42 in forum The Android Central Lounge
    Last Post: 02-05-2010, 02:31 PM
  5. How many of you would use Mobile Firefox?
    By Jeremy in forum Android Applications
    Last Post: 01-02-2010, 02:57 AM
