So this is my second dna, the first one would sort of creak if the corners were pressed on. So I swapped it out and got a new one, no creaks or noises whatsoever. However, over time this o e has started doing the same thing. Even worse than the first even. It sounds like the two pieces of the phone are setting against each other. Kind of like clicking a case together. Anyone else had this "issue"? I'm only kind of worried about it, doesn't affect performance at all.
