Results 1 to 10 of 10
    Default Sound Profiles
    Is there any way to create sound profiles that have different combinations? In other words, at night I would like to have everything silent except for the phone, at work I would like the phone silent and only calendar and task reminders audible. I was able to do this with my Blackberry, but have not been able to figure out how with my DNA.
    Thank you!
  2. #2
    Irvgotti's Avatar
    Posts
    Global Posts
    1,042 Global Posts
    ROM
    Stock Sense 4.1.1
    Default Re: Sound Profiles
    Maybe down load sound profile from the play store
    Sent from my HTC6435LVW using Android Central Forums
    Privacy is overrated :P
    Thanked by:
  3. #3
    Quote Originally Posted by golson22m View Post
    Is there any way to create sound profiles ... at night I would like to have everything silent except for the phone, at work I would like the phone silent and only calendar and task reminders audible.
    LightFlow can achieve this if you set exceptions-->
    Thanked by:
  4. #4
    Audio Manager Free/Pro can do all that for you. Fantastic program...HOWEVER, I've noticed a bug where if you change the profile it'll change your default notification and ringtone. I've emailed the developer. But it does change all the profiles no problem.
    Thanked by:
  5. #5
    Quote Originally Posted by dbdynsty25 View Post
    Since ICS, the ringtone volume and notification volume are married - you cannot adjust them independently anymore. Apps such as Audio Manager have the option for notification volume removed on ICS/JB devices. There's a HUGE thread on the Android support pages about this, with people pleading for the past year to return that functionality. Google has remained silent.
    The only solution I came up with, was to use Tasker to create a profile that does the following:
    12:30 AM - Turn on silent mode
    If the phone rings, turn the ringtone volume up (and remain up for 5 minutes before going back to silent mode)
    7:00 AM - Turn silent mode off
    You could also customize the script to only allow certain numbers, but I don't get many calls overnight so all calls are fine for me.
    I can post the Tasker code if anyone is interested. Edit: posted below.
  6. #6
    Quote Originally Posted by paulmike3 View Post
    Yes please. :-)
  7. #7
    Quote Originally Posted by underdonk View Post
    Yes please. :-)
    Here are the two profiles you'll need ( & ). Let me know if they import into Tasker OK. Never exported/imported before. I can do it differently (screenshots or something) if this doesn't work.
    Edit: Here's how to import them, in case anyone is confused
    1.) On your device, click on the the two XML files above and download them to your device (they'll be in the "download" folder).
    2.) Launch Tasker on your device
    3.) Long press on the "Profiles" tab along the top
    4.) Select "Import"
    5.) Using the carrot icon on the right, navigate to your "download" folder
    6.) Select the first xml file, and import it.
    7.) Repeat the process above for the second xml file
    8.) Make sure they're enabled in Tasker
    9.) Modify the scripts to fit your needs. They're initially set for 12 am on and 7 am off, and to allow all calls. You can change the times and add specific numbers to allow (use the magnifying glass to select contacts).
    Thanked by:
  8. #8
    Sorry to be a newbie pest -- if I were to buy Tasker this is all (initially) I would use it for, but it would be well worth the $2.99. Do I need to install both scripts -- sleep mode turns off the phone and sleep mode emergency turns it on when a call comes in? Will I have to burrow into the code to change the time settings or is there some interface I will be able to use for that?
    4.) Select "Import"
  9. #9
    I got brave, bought tasker, downloaded and imported your profiles, modified them to fit my sleep patterns -- thank you very much!!
  10. #10
    I did a little testing with this, and it seems like if you get a phone call during the Sleep Mode and thus activate the Sleep Mode Emergency profile, after the phone call the phone is un-silenced and the Sleep Mode profile is overridden. If this is the case, is there a way to "reactivate" the Sleep Mode so it silences the phone once again?
  1. sound profile app
    By Lurch81#AC in forum Android Applications
    Last Post: 05-09-2010, 12:35 AM
  2. Sound Profiles
    By roman08225 in forum Verizon Droid Incredible
    Last Post: 04-28-2010, 09:38 PM
  3. Sound Profiles
    By Justin89t in forum Verizon Droid Incredible
    Last Post: 04-24-2010, 02:40 PM
  4. Sound Profiles
    By passtheboll in forum Android Applications
    Last Post: 03-13-2010, 02:49 PM
  5. Sound Profiles
    By cward0625 in forum Motorola Droid
    Last Post: 11-11-2009, 02:56 PM
