Results 1 to 16 of 16
    AndroidXTC's Avatar
    Posts
    ROM
    None
    Default Will The Wireless Charger Work Through a Case?
    Or do you have to remove it?
  2. #2
    Default Re: Will The Wireless Charger Work Through a Case?
    It really depends on the case.
    Sent from my HTC6435LVW using Android Central Forums
  3. #3
    My DT-910 works through my Incipio Feather case.
    Swyped from my DNA on Tapatalk 2.
  4. #4
    nextcity's Avatar
    Posts
    Global Posts
    192 Global Posts
    Yes. The only case I know of that will not work is an Otterbox. I believe that charging with a case on may actually be better for the long-term life of the battery, as it lowers the peak charging temperatute by about five degrees.
  5. #5
    Irvgotti's Avatar
    Posts
    Global Posts
    1,042 Global Posts
    ROM
    Stock Sense 4.1.1
    It works with the commuter
    Privacy is overrated :P
  6. #6
    I thought I remembered reading somewhere that if you lined it up just right it worked with the Otterbox Defender too?
    Sent from my HTC6435LVW using Tapatalk 2
  7. #7
    Quote Originally Posted by coolbreeze View Post
    I think that's the deal with any of the thicker cases. Wireless charging works with my Ballistic SG, but placement on the pad is significantly more particular.
  8. #8
    I have the Incipio Faxion and it works perfectly with the Nokia dt910. It's not picky at all, just place and forget.
    Sent from my DNA
    AndroidXTC's Avatar
    Posts
    ROM
    None
    I just got the Nokia branded charger and to answer my own question YES it works just fine through my TPU case I love this thing!
  10. #10
    Quote Originally Posted by nextcity View Post
    Not true for me. My Nokia DT 900 worked fine with the Otterbox Defender. I got a case less bulky..the Seidio Active with kickstand and charges fine with this one as well.
    Thanked by:
  11. #11
    I've got a ballistic SG too. How do you line it up? Is it difficult? I read elsewhere that it doesn't charge. What charger do you have?
  12. #12
    I have a Seidio active and Cruzerlite and my phone charges with either on the Nexus orb charger.
  13. #13
    KarbonKopy's Avatar
    Posts
    ROM
    Random ROM/Stock
    Same here. Have a Cruzerlite case on my phone and it charges like a champ!
  14. #14
    luke31's Avatar
    Posts
    Global Posts
    493 Global Posts
    ROM
    AOKP JB Build 3
    Wireless charging works flawlessly with my Cruzerlite Androdified TPU case. I use the standard Nokia wireless charger (picked up at VZW store), and the phone charges in almost any position, as if the case didn't impede the "chargability" at all.
    Droid DNA by HTC
    Nexus 7 16GB
  15. #15
    brandonx1000's Avatar
    rule the air.
    Posts
    Global Posts
    1,031 Global Posts
    no issues with my otterbox defender
  16. #16
    unklsckness's Avatar
    Posts
    Global Posts
    60 Global Posts
    ROM
    Scotts CleanRom 4.3
    No problems on either Incipio cases.
  1. Will a wireless adapter work on the Xoom?
    By freddofrog in forum Motorola Xoom
    Last Post: 06-14-2011, 01:41 AM
  2. Will a Blackberry charger work with the DI2?
    By CSI Guy in forum Verizon Droid Incredible 2
    Last Post: 05-30-2011, 05:11 PM
  3. Will this car charger work?
    By D Evo in forum HTC EVO 4G
    Last Post: 06-29-2010, 09:19 PM
  4. Will the Pre Charger work with the Evo?
    By krue92 in forum HTC EVO 4G
    Last Post: 06-04-2010, 08:40 AM
  5. So will the Nexus One work on AT&T?
    By Jibeker in forum Google / HTC Nexus One
    Last Post: 01-04-2010, 10:18 PM
