Results 1 to 6 of 6
- 02-13-2013, 07:53 PM
Thread Author #1
Not staying connected to DT-900 charger
I purchased a Nokia DT-900 charger for my DNA about a month ago. Has been working great, and love the convenience. I charge every night while sleeping. I pulled the phone off the charger this morning and found my battery was almost drained. I put the phone back on the charger and the notification came up on the screen that wireless charging was enabled, but a few seconds later it reported it was disconnected. Tried that several times with similar results. Finally figured out that if I put a little weight on top of my DNA (TV remote), it would stay connected. Has anyone else run into a similar problem? I don't know if it indicates a problem with the charger or the phone since I don't have a second of either device.
- 02-14-2013, 12:20 AM #2
Re: Not staying connected to DT-900 charger
Mine works ok - So far - no disconnect problems with the case from verizons case clip combo
Been using it for 2 weeks now - I would be taking it & the phone back to verizon store to see if its the pickup in the phone or charger
You say a little weight makes a difference then I would think the contacts inside the back cover of the phone are bad
Just my 21/2 cents - 02-14-2013, 01:29 AM #3
In a case or not? I also have that charger, and haven't had any issues.
- 02-14-2013, 05:57 AM
Thread Author #4
Not in a case. I have charged it with my case on in the past without issue. However, I have an Xway steel disc mounted on the back of the case, and when I place that on the charger it gets pretty warm, so my routine the last couple of weeks has been to charge it without the case on. Guess I'll take it to the VZW store over the weekend.
- 02-15-2013, 12:49 PM #5
Well it might be the phone or it might be the charger. I have the same one and it works fine even through a thick case.
- 02-16-2013, 03:34 PM
Thread Author #6
Went to the VZW store today. Rep placed my phone on another QI charger, and placed his personal DNA on my charger. Mine charged for about 3 minutes and then stopped, but his charged without issue on my charger. He looked for any info in their internal systems, and apparently have had a couple other cases similar to mine. They are sending a replacement phone to me.
Nexus 7 not staying connected to Connectify Hotspot/Windows Hotspot
By omorgan88 in forum Google Nexus 7 TabletReplies: 1Last Post: 12-11-2012, 02:18 PM -
4G Hotspot does not stay connected to 4G disconnects all the time
By Vphung in forum Verizon HTC ThunderboltReplies: 97Last Post: 03-30-2012, 03:54 PM -
Optimus not staying connected to 3G
By outdors21 in forum LG Optimus SReplies: 10Last Post: 03-31-2011, 11:22 AM -
Bluetooth will not stay connected to vehicle hands free system
By templetonryecy in forum Verizon HTC ThunderboltReplies: 6Last Post: 03-25-2011, 11:20 PM -
Evo will not stay connected to PC with USB cable
By htcStEVO in forum HTC EVO 4GReplies: 6Last Post: 01-06-2011, 08:29 AM
Reply
