1. roadking2013's Avatar
    So, I just got my DNA and glanced through the little quick set up tablet and it says to fully charge before powering up unit to activate my account. No where in the booklet or online tells you about the indicator on the phone when its off? I'm assuming the orange light is charging and eventually will turn green when fully charged??
    Sent from my 2nd Brain....
    02-15-2013 08:38 PM
  2. Jennifer Stough's Avatar
    It never turns green. It will turn off when fully charged I believe. I normally charge while sleeping so I can't say for certain whether it turns off but I believe when I've checked my phone in the morning at 100% the light was off
    Sent from my HTC6435LVW using Android Central Forums
    02-15-2013 08:59 PM
  3. roadking2013's Avatar
    Humm...that's strange....thanks for the reply...can't want till the AM
    02-15-2013 09:14 PM
  4. Stevini18's Avatar
    Mine is definitely orange while charging and then turns to green when fully charged. No light is present when not connected to charger, unless you have super low battery - then it flashes red. Takes a while to get full 100% charge. Mine tends to stay at 99% then after like another 30 minutes, it gets to 100%....
    02-15-2013 09:55 PM
  5. mightyfacundo's Avatar
    Same for me.
    Sent from my DNA
    02-15-2013 10:01 PM
  6. wernd's Avatar
    100% green here
    02-15-2013 11:00 PM
  7. roadking2013's Avatar
    All good here .... green is charged
    02-16-2013 07:52 AM
  8. Jennifer Stough's Avatar
    That makes me sad then. I have never had a green led. Just watched it reach 100% and the orange light deactivated upon completion.
    02-16-2013 11:11 AM
  9. Mikey D_PhD's Avatar
    Sounds like you have a faulty LED.
    02-16-2013 12:57 PM
  10. Jrocker23's Avatar
    I get a green light too when at 100%
    Sent from my Droid DNA using Tapatalk 2...
    02-17-2013 07:22 PM
  1. Homescreen vs Camera Battery Indicators...
    By Joeybear23 in forum AT&T Captivate
    Last Post: 10-29-2011, 10:22 AM
  2. Remove stock battery indicator in status bar?
    By droidntn in forum Motorola Droid X
    Last Post: 07-31-2010, 09:33 PM
  3. Battery status pro Vs. battery indicator
    By scooz16 in forum Android Apps
    Last Post: 07-14-2010, 05:01 PM
  4. Battery Indicator is Waaay Off
    By LocationDudeNYC in forum HTC EVO 4G
    Last Post: 06-07-2010, 08:37 AM
  5. Sudden Dead Battery Indication
    By Chris Kerrigan in forum Motorola Droid
    Last Post: 03-13-2010, 11:09 PM
