Results 1 to 10 of 10
    Default DNA's external top battery indicator?
    So, I just got my DNA and glanced through the little quick set up tablet and it says to fully charge before powering up unit to activate my account. No where in the booklet or online tells you about the indicator on the phone when its off? I'm assuming the orange light is charging and eventually will turn green when fully charged??
    Sent from my 2nd Brain....
  2. #2
    Jennifer Stough's Avatar
    Retired Moderator
    Posts
    Global Posts
    2,032 Global Posts
    Default Re: DNA's external top battery indicator?
    It never turns green. It will turn off when fully charged I believe. I normally charge while sleeping so I can't say for certain whether it turns off but I believe when I've checked my phone in the morning at 100% the light was off
    Sent from my HTC6435LVW using Android Central Forums
    Quote Originally Posted by Jennifer Stough View Post
    Humm...that's strange....thanks for the reply...can't want till the AM
  4. #4
    Mine is definitely orange while charging and then turns to green when fully charged. No light is present when not connected to charger, unless you have super low battery - then it flashes red. Takes a while to get full 100% charge. Mine tends to stay at 99% then after like another 30 minutes, it gets to 100%....
  5. #5
    Quote Originally Posted by Stevini18 View Post
    Same for me.
    Sent from my DNA
  6. #6
    100% green here
    All good here .... green is charged
  8. #8
    Retired Moderator
    Posts
    Global Posts
    2,032 Global Posts
    That makes me sad then. I have never had a green led. Just watched it reach 100% and the orange light deactivated upon completion.
  9. #9
    Mikey D_PhD's Avatar
    Posts
    ROM
    Stock
    Sounds like you have a faulty LED.
    "He didn't fall? Inconceivable".
    "You keep using that word. I do not think it means what you think it means".
  10. #10
    I get a green light too when at 100%
    Sent from my Droid DNA using Tapatalk 2...
    HTC One - VZW
    Try Out DropBox, get your files when you need them, its free http://db.tt/LUr0eAv
  1. Homescreen vs Camera Battery Indicators...
    By Joeybear23 in forum AT&T Captivate
    Last Post: 10-29-2011, 10:22 AM
  2. Remove stock battery indicator in status bar?
    By droidntn in forum Motorola Droid X
    Last Post: 07-31-2010, 09:33 PM
  3. Battery status pro Vs. battery indicator
    By scooz16 in forum Android Apps
    Last Post: 07-14-2010, 05:01 PM
  4. Battery Indicator is Waaay Off
    By LocationDudeNYC in forum HTC EVO 4G
    Last Post: 06-07-2010, 08:37 AM
  5. Sudden Dead Battery Indication
    By Chris Kerrigan in forum Motorola Droid
    Last Post: 03-13-2010, 11:09 PM
