Battery life after update?
Normally I have to TRY and drain the battery to get below 10% before charging at night. Today (first day after update) my battery life was horrible. Noticed HTC Sense and Android OS were at the top of what was using battery. Those two were usually in the middle of what was using the battery. Wondering if anyone else had the same problem
Re: Battery life after update?
My battery seems to be doing a little better than before actually. After 19hrs off the charger I'm at 42%. HTC used 1% and Android only use 2%.
I played 3 games several times each today, used Flipboard App, 2 Email accnts synced , and a little Facebook. A little over 2hrs screen on time.
My battery went from 90% to 40% overnight. It was awake all night which it has never done. Wifi used to shut off from midnight to 6am but it was on all night as well. Sense seems to be the big culprit. I guess I'll have to monitor things again and try to figure it out.
Whenever there is an update the battery seems to drain faster for a bit then it settles down. Had the same issue, stopped the media download, turned off my live wallpaper restarted the phone a couple of times and it's now fine.
Sent from my SGH-I747M using Android Central Forums
My battery life has gone down since the update. My usage usually gave me about 18 hours of life, but the last 2 days have only gotten about 14. Not terrible, but noticeable. I'm hoping for what Jivegirl14 said, that it will settle in after a few days, otherwise I will have to master reset.
For the people with battery issues, try turning off "fast boot" and then restart. You could have something running in the background that is sitting in memory with fast boot.
Having it off for at least 1 restart may clear it out.
I don't have fast boot on and have reset about 3 times a day since the update. Since it's the weekend I'm not sure how it's doing, but the grind of the week will tell me tomorrow
Where is "fast boot" in settings?
Its under the battery setting..
Ditto. My battery life before the update was excellent. Now it is OK. Will try some of the suggestions made and monitor. Any other explanation/solutions are welcome Quote:
My battery life honestly has seemed to improve. I know the stock battery app isn't completely accurate and doesnt show on screen time, but I've had my phone off the charger for 24+ hours and I've still got juice. I am a moderate user on a WiFi connection with brightness at 25%, auto sync and GPS off.
Sent from my HTC6435LVW using Android Central Forums
1 Attachment(s)
After some battery monitoring I noticed it was awakening multiple times from some app. So looked at accounts and saw that google+ syncing turned back on for me. That must use a lot of battery because I've since turned it off and the awake times have gone way down.
For those of you who are worried about dna battery life . . .
[Only registered and activated users can see links. Click Here To Register...]
I'm sure it's not for everybody but just thought I'd put it out there . . .
. . . or you could just get the razr maxx hd and have 3300 in the phone ;)
Mine seems to be the same more or less.
After 3 days I'm just giving in and doing a wipe. Backing up all my stuff now.
I haven't even receive the update yet
Sent from my HTC6435LVW using Tapatalk 2
Go to settings, software update, check for and it should pop up
I haven't noticed a difference in battery life. However, my GSam battery app says my average battery life has gone up. Before the update it was 1 day 11 hours. Now its 1 day 18 hours. No change in my usage.
1 Attachment(s)
My best run on battery after the update.
Sent from my Verizon Droid DNA
seems like my camera app is draining a lot of battery. more so than usual? maybe. it does seem like my phone is draining battery faster than usual, but i have no proof to back that claim. it doesn't hinder my usage, can still get through an entire day comfortably.
Something has been keeping my phone awake all the time since the update. Still cant figure it out. It is KILLING my battery
Just curious--when you had your phone on at 5:30, was it pretty much fully charged, or was it really down to 85%? My battery does this weird thing where, as the day progresses the initial battery gets lower and lower. My usage is fairly routine: unplug phone, turn on at 8AM on my way to my hour-long commute (usually just the Kindle app + Play music with no wifi/4G). Same thing on my way back, when work/school ends.
In the beginning of the day, it shows my phone was at 100% since 8AM--but by the time I get out of work, it says that my battery was anywhere from ~80-90% since 8AM. Is that happening to you, too?
(just took this screenshot now; it was at full charge when I turned my phone on at 8 AM (which is that chunk of usage that shows prior to 12 PM), but now it shows 90% at 8AM)
^~2-3hrs' screentime mostly without 4G/wifi and partly with a screen dimmer, down to 36% after 17 hours; if anything, I think my battery improved after the update.
It was probably at 85% for me, since I primarily charge only fully at night, if I have charges throughout the day I only charge long enough to where the battery notification looks primarily full. I will keep an eye out on it though to see next full run I do.
Have you used betterbatterystats or GSAM to try to figure it out? I know I had an issue with wakelocks for a few weeks. One was caused by my wireless at my office and the other wakelock was caused by the SIM error that has been plaguing some phones. My solutions were to use 4G while at the office to fix one and to pull out and clean my SIM to fix the other. My battery life has been awesome since.
