Results 1 to 8 of 8
    Default Any way to improve the worthless notification light?
    This thing is worthless in its current state. My previous phone was a Droid X2 which for starters had more than just red/green. I know this is a hardware issue and cannot be fixed.
    But is there any app out there to either make it brighter or change its behavior? I know there are settings in the phone to change when it will turn on to notify you, but no option to change the constant on feature when charging. My phone is often plugged in whether at home, work or in my car. I also like leaving my phone on vibrate about 99% of the time and glancing at it to see if the notification light is on. With the DNA this isn't possible.
    What have you guys used to improve the functionality of the lights? Anything that will make the camera flash blink for a text or call? Or something that disables the idiotic constant on feature for charging?
  2. #2
    Default Re: Any way to improve the worthless notification light?
    Give LightFlow a try, its a great app. Let me know if it works for ya.
    I may be missing something but it seems lightflow disables the rear led
    Camera flash control doesnt work and it will not disable the charge led
  5. #5
    Irvgotti's Avatar
    Posts
    ROM
    Stock Sense 4.1.1
    Light flow only has 3 colors for the dna
    Sent from my HTC6435LVW using Android Central Forums
    Privacy is overrated :P
    Default
    Quote Originally Posted by Irvgotti View Post
    Yep, green, deep orange and orange. the camera flash function won't work
  7. #7
    Ahh my fault, I'm using it on the Maxx HD.
    Maxx HD - T C
  8. #8
    I use Noled. It flashes icons on the screen. You can customize what colors and apps you want for notifications.
    Thanked by:
  1. Any way to modify the notifications bar?
    By jrwatson in forum Verizon Droid DNA
    Last Post: 12-26-2012, 08:30 AM
  2. Any way to change the notification bar shortcuts?
    By sportsplayer5959 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-19-2011, 07:58 PM
  3. Replies: 3
    Last Post: 06-26-2010, 09:21 PM
  4. Any way to quit the internet app?
    By Eazy123 in forum HTC EVO 4G
    Last Post: 06-15-2010, 09:34 PM
  5. Any way to HIDE the battery meter?
    By slinky317 in forum Verizon Droid Incredible
    Last Post: 06-08-2010, 06:44 PM
