Results 1 to 8 of 8
    ether813's Avatar
    Posts
    Global Posts
    70 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default DROID DNA WIreless Charging Issue
    I got a Droid DNA, and recently pickup the Nokia Wireless Charging Pad, not the Pillow one but the other one. I keep having an issue that whenever i lay the phone on the pad to charge, it no longer chargers properly with a wired charger. I would plug it in overnight, and wake up the next morning, that the Battery Indicator would still say "28%", and when i look at the battery history, it just appears that the DNA only maintained the charger when it was plugged in. The only way i could get it to start charging normally again was to disable fast boot and then reboot the device, and then it would charge properly when plugged in. Also it would stay working correctly as long as i didn't attempt to charge it wirelessly again. Anyone ever heard of this.
  2. #2
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,549 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    NOS M7 Sense 5.0
    Default Re: DROID DNA WIreless Charging Issue
    I have two Nokia chargers at home and do wired charging in the car and at the office and have never had any issues between the two. Only thing I can think of doing a factory reset which sucks since you lose all your data. I would wait for a better answer or maybe even all Verizon tech support maybe they'll have something.
    ether813 likes this.
  3. #3
    masseurca's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also no issues here switching between the chargers.
    Sent from my HTC6435LVW using Android Central Forums
  4. #4
    tuxly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have nokia 900 pad and only occassionally do wired charging, but have no problems like that either. Did lose ability to charge wirelessly on first phone, but wired charging still worked fine. Your issue seems to be a differnt one but may be tied into same problem with losing wireless charge capability. If this persists, I would see about getting new device.
    ether813's Avatar
    Posts
    Global Posts
    70 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the replies...I will give a factory reset a shot on Friday and see if it still acts up on the weekend and if that is the case just look to get a replacement on monday
  6. #6
    FiloBeto's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same problem, its not my charger it works with the other phones i have. if I push down on the phone while its on the charger it keeps the charging connection, when I release the pressure it drops the connection. feels like maybe the back non removable cover is warped outward so the phones charging device is to far away from charger. if you push down on your phone does it keep the connection?
  7. #7
    jerrykur's Avatar
    Posts
    Global Posts
    1,232 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by FiloBeto View Post
    If the back is warped it makes sense that there would be an issue. There is a metal coil on the inside of the back that is used to transfer the power.
  8. #8
    KSDroid01's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jerrykur View Post
    Hmmmm....not so sure. My DNA has a Siedi cover on it and charges fine...surely the cover is thicker than a warp in the back plate? Could there possibly be a bad connection in the charging coil in the back plate?
    Posted via the "Best Smartphone of 2013" One
  1. HTC DROID DNA w/ Nokia DT-900 Wireless Charging and Extras
    By nDroid3 in forum Marketplace Archive
    Last Post: 02-15-2013, 09:19 AM
  2. Droid DNA connected to PC issue
    By Wojofoo in forum Verizon Droid DNA
    Last Post: 01-24-2013, 07:57 PM
  3. Droid DNA issues
    By haack48 in forum Verizon Droid DNA
    Last Post: 11-29-2012, 06:54 PM
  4. Droid Incredible Album art issue!!
    By vblok0910#WP in forum Verizon Droid Incredible
    Last Post: 06-13-2010, 07:43 AM
  5. Charging Issue
    By Fazulka in forum HTC Hero
    Last Post: 05-16-2010, 09:41 PM
