Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By Wingznut
    law2010's Avatar
    Posts
    Global Posts
    43 Global Posts
    Default Google Maps draining battery while closed
    My new DNA has pretty terrible battery life. When looking at the battery usage, it looks like Google Maps is the culprit.
    I have not opened the maps app and use advanced task killer to close apps constantly.
    I turned off Google Latitude and still have abysmal battery life. I cannot make it through a basic workday without the phone draining to almost nothing.
    Anyone know what is causing this?
    Attached Thumbnails Attached Thumbnails Google Maps draining battery while closed-2013-02-19_09-47-58.jpg   Google Maps draining battery while closed-2013-02-19_07-55-47.jpg
  2. #2
    Default Re: Google Maps draining battery while closed
    Quote Originally Posted by law2010 View Post
    Try not doing that... At all. Let Android handle app management.
    paulmike3 likes this.
    law2010's Avatar
    Posts
    Global Posts
    43 Global Posts
    Thanks, but the Maps App is obviously being activated by something and it is using a disproportionate amount of my battery versus everything else. I think that is my main power problem.
  4. #4
    Every time you force close maps it will restart usually automatically and will definitely kill the battery. Also other apps and the browser I see in the screen shot uses location check settings in popular apps that you use and turn off their location settings. I hope that helps a bit.
    Sent from my DROID RAZR using Android Central Forums
  5. #5
    If you are not using Google Now, turn it off. It does alot of location based stuff.
  6. #6
    atakin77's Avatar
    Posts
    Global Posts
    66 Global Posts
    ROM
    CND 1.3.3
    I think this is a broader Jelly Bean issue with Maps, I've read about it on other devices as well. Hopefully Google will release an update to Maps that addresses it.
  7. #7
    jf2go's Avatar
    Posts
    Global Posts
    83 Global Posts
    After the update, I had Google Maps in "stalker mode" reporting my whereabouts periodically throughout the day, and looking for places to check-in, and I saw the same skewed battery usage for Maps. I turned all of that off and today it is back to normal - Maps is at 7% App Usage. I am in WiFi most of the day today, so I'm not 100% sure the problem is solved.
  8. Thread Author  Thread Author    #8
    law2010's Avatar
    Posts
    Global Posts
    43 Global Posts
    Quote Originally Posted by jf2go View Post
    When you refer to turning all that off, what are you referring to specifically? If I go into Google Maps, settings, and shut everything off, which includes latitude, it still does not fix the problem.
    It must be some other app that is pulling my location, but I can't figure out what. I do not want to wipe out Facebook or the weather widget, but I am wondering if they are pulling my location all the time.
    It's very strange.
  9. #9
    I had the same issue for a week, Google maps was using 25-30% of my battery. I figured 1 of the 3 Apps I installed that week might be the culprit so I uninstalled them. Battery has been fine ever since. I think there may some badly written apps out there that continuously pool your location for ADs.
    Also, anyone else notice in running apps that you may have 2 Google maps running when you aren't even using it? I can't figure this one out yet.
  10. #10
    jf2go's Avatar
    Posts
    Global Posts
    83 Global Posts
    It's very strange.
    In Google Maps -> Settings -> Location Settings, I don't have anything checked. I am still using Google Now, which seems to know where I am and provide relevant cards.
    I also have Facebook installed, and am allowing the Sense weather widget to update.
  11. #11
    Irvgotti's Avatar
    Posts
    ROM
    Stock Sense 4.1.1
    Turn off all the location settings
    Sent from my HTC6435LVW using Android Central Forums
    Privacy is overrated :P
  12. #12
    jf2go's Avatar
    Posts
    Global Posts
    83 Global Posts
    Google Maps was updated today - notes say "bug fixes". I just re-enabled report my location from this device in location settings to see if the Maps battery usage goes nuts again.
  13. Thread Author  Thread Author    #13
    law2010's Avatar
    Posts
    Global Posts
    43 Global Posts
    Default
    I just updated maps and re-enabled everything. Hopefully that resolves the problem.
    I will try to keep you posted.
  14. #14
    I had the same issue disabled the maps app because I rarely used it and my battery life went way back up to over a day
    Sent from my Red Droid DNA
    Thanked by:
  15. Thread Author  Thread Author    #15
    law2010's Avatar
    Posts
    Global Posts
    43 Global Posts
    After the google maps update, I have not experienced any change. The app or a rogue app tapping google maps is still eating most of my battery life.
  16. #16
    It's very strange.
    Report from this device in the settings menu may be the culprit.
    Sent from my Nexus 7 using Tapatalk HD
  17. #17
    Can't figure this out. Frustrating. Same problem. Unbelievably inefficient and a waste of battery resources. Can't wait to learn what the culprit is.
  18. #18
    Having the exact same issue. If anyone figures it out I'd love a way to get my battery life back!
  19. #19
    brandonx1000's Avatar
    rule the air.
    Posts
    Global Posts
    1,030 Global Posts
    i had to disable the app to get it to stop...sucks, but it was the only way
  20. #20
    Uninstall all map updates on your phone, and turn off location sharing in the app. This will majorally fix the problem. If all else fails, disable the app. If you check your battery graph, is your phone being awakened when the screen is not on? I found that was the problem with Google maps, it was using 30% of my battery and keeping my phone awake 24/7.
    Sent from my Verizon Droid DNA
  21. #21
    I had the same problem, just uninstall Google Map updates and problem is fixed
    You can see from the image the updates keep the phone always awake even if screen was off. Once I removed the updates, the phone was not awake when not using it
    Attached Thumbnails Attached Thumbnails Google Maps draining battery while closed-google-maps-battery-drain.png
  1. Google+ App draining battery
    By gsweinberg in forum HTC One X
    Last Post: 01-05-2013, 12:24 PM
  2. Google Maps -> Navigation = Battery destroyer....
    By brava27 in forum Samsung Galaxy S3
    Last Post: 07-16-2012, 11:39 AM
  3. Google Maps killing battery?
    By rpscott02 in forum Droid Bionic
    Last Post: 11-12-2011, 09:59 AM
  4. Google Voice draining battery.
    By Jalarm in forum T-Mobile Nexus S
    Last Post: 01-30-2011, 04:48 PM
  5. Google Voice draining battery?
    By void.pointer in forum AT&T Captivate
    Last Post: 09-21-2010, 01:27 PM
