Results 1 to 7 of 7
- 02-22-2013, 03:19 PM
Thread Author #1
Can anyone help me figure out what my screen does this?
My wallpaper changes size on it's own. I set the wallpaper picture and after a few minutes it changes size.Can anyone help me fix this? The picture on the right is the way it set it, it changes to the size of the one the left.
- 02-22-2013, 06:08 PM #2
Re: Can anyone help me figure out what my screen does this?
It's either your launcher or if your using a 3rd party application to change wallpaper like PicSpeed. This happened to me once and I believe it was my launcher because I enabled my home screen go into lanscape. Are you using a wallpaper app? and what launcher are you using? You could try setting that wallpaper to the Sense launcher and see if that problem happend then even switch back to your other launcher.
- 02-23-2013, 04:58 AM
Thread Author #3
I am running Nova launcher. I did try starting it in the HTC sense launcher.It only stops if I turn off the Nova launcher, so I guesss that's the source of my problem. I just wish I could fix it. It didn't do this when I first installed Nova. Well thanks for the help.
- 02-23-2013, 12:22 PM #4
Check some of the wallpaper / launcher settings they usually have a crop option for just this thing..
- 02-23-2013, 12:44 PM #5
As annoying as it is to have a billion tiny apps, you might try downloading a 3rd party wallpaper app. I'm using "Simple Image Wallpaper Free", which allows me to set 1920x1080 images exactly as is.
- 02-23-2013, 02:48 PM
Thread Author #6
- 03-05-2013, 01:11 PM #7
Can anyone help me figure out......
By emdeedee in forum Google / Samsung Galaxy NexusReplies: 1Last Post: 12-04-2012, 12:21 AM -
Can someone help me figure out how much tax and surcharges Ill be paying?
By Oxn in forum SprintReplies: 6Last Post: 09-14-2012, 10:10 AM -
Help me figure out what widget this is!!!!!
By CFD323 in forum Verizon Galaxy NexusReplies: 1Last Post: 08-20-2012, 09:00 PM -
Can somebody help me figure out what is causing this?
By gospodinjuha in forum Thunderbolt Rooting, ROMs, and HacksReplies: 3Last Post: 08-03-2012, 12:41 AM -
Can someone help me figure out how to do a hangout?
By greydarrah in forum Verizon Galaxy NexusReplies: 8Last Post: 12-31-2011, 10:34 AM
Reply
