Results 1 to 6 of 6
- 03-13-2013, 09:12 PM
Thread Author #1
Droid DNA will not turn on. WTF?
I have had the DNA since it came out, so this is not a replacement or a refub.
I have noticed in the past week that the battery is draining really quickly. I can go a whole day without my battery turning yellow and lately I have been having to charge it about 4 or 5 hours before I go bed. Today, I picked up my phone and the battery was in the red, after being off of the charger for only 4 hours and using it for 30 minutes. I attached it to the USB cord and plugged it into my laptop and the phone shut down after about 45 seconds of charging. I plugged the charger into the wall and waited about 10 minutes for it to get a little bit of a charge before trying to turn it back on. After pressing the power button for 15 seconds, it would vibrate and show the white "HTC" screen, then turn itself back off. This is all it would do. After 45 minutes, I tried turning the phone back on after unplugging it from the charger and it booted up just fine.
Just now, about an hour and a half after the first incident, I received a text and the phone shut itself down and will not turn back on, again. Last time I checked, the battery was at 34%. Again, I cannot get past the white HTC screen without the phone shutting itself back off. Also, I read that if you hold the power button down for 20 seconds, you will see three LED lights flash and this signals the phone to reset itself and boot back up. I've tried it and it didn't work.
Does it sound like the battery is going so dead so quickly that the phone will not power up?
I guess either way, whether it is the battery or some other defect, I'll have to take it to VZW. I REALLY don't want to do that. I REALLY don't want a refurb.
Has anyone experienced this? What had to happen to remedy the problem? Thanks in advance!! - 03-14-2013, 08:56 AM #2
Re: Droid DNA will not turn on. WTF?
Get it charged up and, try a factory reset. that might do the trick.
My Rezound did something similar, it got to about 30% and, the battery drain started to accelerate. One tip after you get it turned on, would be to turn off Mobile Network, that should stop the crazy battery drain. A factory reset fixed my Rezound, and, it behaved much better after that.
Good Luck - 03-14-2013, 06:41 PM #3
- 04-16-2013, 08:08 PM #4
- 04-17-2013, 07:49 PM #5
I've never had this problem, but perhaps you should let it stay on the charger for what would represent a full charge (4 hours or so?) And try to turn it back on from there. If it doesn't turn back on, try the factory reboot method with hardware keys.
Sent from my Verizon Droid DNA
- 04-19-2013, 12:24 AM #6
I would plug it in to the factory charger and wait several hours before powering up the phone. When it comes up use it for a while and then determine which app is using the battery.
Xoom will not turn on
By FireGuy303 in forum Motorola XoomReplies: 28Last Post: 03-18-2013, 02:24 PM -
Droid's Screen Will Not Turn On??
By GAlex067 in forum Motorola DroidReplies: 4Last Post: 01-19-2011, 08:22 AM -
blackflip will not turn on!!!!!!1
By bigheadtony6 in forum Motorola BackflipReplies: 2Last Post: 11-04-2010, 04:02 PM -
Inc will not turn on, no charge light
By superstar in forum Verizon Droid IncredibleReplies: 3Last Post: 09-23-2010, 10:29 PM -
Phone will not turn on
By kvaughan#ac in forum Verizon FascinateReplies: 4Last Post: 09-14-2010, 08:39 AM
Reply
