Results 1 to 5 of 5
- 03-22-2013, 07:26 PM
Thread Author #1
Replacement issue?
I noticed this a couple of days ago (this was a refurbished warranty replacement I got a week or so ago). There seems to be a gap near the bottom, but I can't remember whether or not it was like this on the last unit. It looks like the capacitive button backlight can be seen at the gap between the plastic and glass. I don't care about it too much, but I don't think it would help resale value too much down the road if this is a problem.
- 03-22-2013, 08:01 PM #2
Re: Replacement issue?
google DNA light leak, seems like its a common thing for some and not for others.
i remember when the thunderbolt came out it had bad light leak problems, i myself sent back 3 units for the problem. if you feel it will hurt the value send it back for another one. then again its hard to tell how good the seal between the bezel and digitizer would be. - 03-22-2013, 09:06 PM #3
I have a light leak on the screen from the capacitive buttons, but there should not be a gap between the glass and the back of the phone. I'd send it back. Looks like someone did a tear down and didn't reassemble it properly.
Sent from my Verizon Droid DNAThanked by: - 03-23-2013, 05:14 PM #4
Yea same here with the thunderbolt. I dont have it on this DNA however. They use double faced tape to glue the digitizer down to the chassis, what you are seeing are gaps in the tape where its not sticking down completely. The tape also serves as a gasket of sorts as well.
- 03-30-2013, 10:00 AM
Thread Author #5
So,I got the thing replaced and the one they sent me is either missing the right-most capacitive button led bulb or it has burnt out. 100-point inspection nonsense in such BS. I've about had it with Verizon.
Home Replacement issues
By shamefulzero in forum Motorola Droid 3Replies: 3Last Post: 08-13-2011, 08:05 PM -
Home replacement issues??
By ben1284 in forum Verizon HTC ThunderboltReplies: 2Last Post: 07-06-2011, 11:49 PM -
Evo replacement for constant reboot issue
By darkborne in forum HTC EVO 4GReplies: 5Last Post: 12-20-2010, 10:04 AM -
Home Screen Replacement Issues
By wayne22 in forum Android ApplicationsReplies: 8Last Post: 03-19-2010, 02:26 PM -
By wayne22 in forum Motorola DroidReplies: 7Last Post: 02-06-2010, 11:58 AM
Reply
