Results 1 to 6 of 6
    Default LED Stops Flashing
    Is the LED notification supposed to stop flashing after only about 10 or 15 minutes? My previous phone was a Droid Charge and it didn't have one so I don't know if that's just how the android system works or not.
    Sent from my HTC6435LVW using Tapatalk 2
  2. #2
    neil154's Avatar
    Posts
    Global Posts
    391 Global Posts
    Default Re: LED Stops Flashing
    LED notification is dependent upon the app so check you setting for it in that app
    Galaxy S3 16GB Unrooted Pebble Blue
    Verizon,USA
    Android V4.3
    I can't seem to find a setting in Gmail or the stock messaging app that controls the length of time the LED flashes. I just want it to flash until I acknowledge it instead of it going away after a short period of time
    Maybe I should be asking if this is how everyone's DNAs behave...
  4. #4
    Is "LightFlow" compatible with the DNA?
    Here's the link to the free version to try-->
  5. #5
    Yeah it stops after x-amount of minutes. Mine does the same thing. I think after about 5 minutes it stops flashing.
    Sent from my HTC6435LVW using Android Central Forums
  6. #6
    I just noticed my LED inidicator stops flashing after 5 minutes. It's so aggravating as I have missed important texts. The indicator on my Bionic continued to flash until I acknowledged it. Don't understand why my DNA doesn't.
  1. Replies: 8
    Last Post: 03-24-2011, 11:11 PM
  2. Getting LED to flash while charging?
    By big_bake in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 03-13-2011, 12:32 AM
  3. Why does the LED stop blinking?
    By sum spicy rice in forum Verizon Droid Incredible
    Last Post: 05-26-2010, 02:20 PM
  4. Anyone else's notification LED stop blinking after a while?
    By Jasonrj in forum Verizon Droid Incredible
    Last Post: 05-07-2010, 07:41 AM
  5. LED not flashing when screen comes on.
    By Vacuus Dilectio in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-15-2010, 03:25 PM
B
