1. UseAndroid86's Avatar
    For the last few months I've been having some annoying issues with the Google navigation on my phone. It won't recognize my home address sometimes. It will take me way out of my way to get somewhere. It will have me get off a road go through a neighborhood then get back on the same road.(no traffic issues in those areas either) so I'm wondering if anyone else is experiencing these types of things. I've went into the settings and all I saw is the option to avoid highways or tolls. Sorry if this topic is in the wrong place.
    Sent from my HTC6435LVW using Android Central Forums
    04-10-2013 07:58 PM
  2. iOS Gravity's Avatar
    Factory restore it then check mark restore back up from google account.
    04-10-2013 08:16 PM
  3. UseAndroid86's Avatar
    Okay will do. I'll post in a couple days a difference or not. Thanks for the reply
    04-10-2013 09:03 PM
  4. iOS Gravity's Avatar
    If it doesn't work get a replacement from your carrier. But 99.99% of the time it fixes almost any errors on your phone.
    04-10-2013 09:38 PM
  5. jamdmyers's Avatar
    You might consider going into the app and clearing just the navigation data/cache.. factory reset is a bit of a big hammer approach.
    go to apps find navigation (and google maps) longpress them clear the data/cache areas
    04-11-2013 07:27 AM
  6. UseAndroid86's Avatar
    I did clear out the cache and data and uninstalled all updates. I didn't reset my phone. I think that would be a little too extreme in my opinion. I did ''reset'' the maps. I'll start with that and see if that helps. So far it does recognize my home address and going to a new address today seemed to be correct. So maybe it was that simple of a fix. Thanks for the responses so far.
    04-11-2013 06:14 PM
  1. Gps navigation issues
    By NIKSTORM in forum Verizon Galaxy S III
    Last Post: 08-20-2012, 05:58 PM
  2. GPS/Navigation Issues?
    By BillCase in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 02-18-2012, 08:28 PM
  3. Thunderbolt GPS Navigation Issue??
    By jkim723 in forum Verizon HTC Thunderbolt
    Last Post: 08-09-2011, 08:21 PM
  4. Liberty ROM & GPS Navigation Issues
    By tinmannick in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 01-30-2011, 09:07 AM
  5. 3 Questions re: Voice Dictation, GPS Navigation, Optical joystick
    By tjubb in forum Verizon Droid Incredible
    Last Post: 05-15-2010, 06:40 PM
