- Sep 9, 2010
- 1,312
- 12
- 0
Should have done this when I first picked up the DNA.
Got tired off that little USB cover every time I wanted to charge (car and home).
But didn't want to tear it off if I ever wanted to sell it.
Picked up 2 Nokia DT900 charging pads, modified one for the car use the other for home charging. The plug ends are the same on both sides.
[/URL][/IMG]
[/URL][/IMG]
I had 2 car mounts to choose from, Exogear Exomount and iBolt for DNA
Hate how strong the spring is on the IBolt so decided to work with the Exomount.
[/URL][/IMG]
The car mount mod was easy; cut one end of the charging wire (only set up to work with the supplied wall adapter) and spliced it to a micro fuse tap (google it). The outer casing wire is the ground and the inner is the hot.
[/URL][/IMG]
Took the charging pad and epoxied the bottom to the bottom clamp of the Exomount, done.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
With the bottom of the charging pad epoxied I just squeeze the clamp open and the charging pad remains on the bottom and the top clamp opens enough to insert the DNA. Close clamp and it begins to charge.
No more wires or that stupid USB cover to deal with.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Took about a half hour to modify and install (let the epoxy sit overnight). I like hidden wires so I took the time later (about an hour) to hide all the wires behind the dash as well as hooking up a headphone jack wire to play music and phone calls through the stereo.
[/URL][/IMG]
