Results 1 to 18 of 18
    Default Internet is using 70-75% of battery after firmware update
    Ever since the DNA firmware update, my battery barely lasts 24 hours without me even using it! When i check to see what is using the battery, it shows me that internet is using a whopping 70-75% of the battery. Is anyone else seeing this, and if so, have you found a solution? FYI, i haven't done a hard reset yet, just a soft one.
  2. #2
    Default Re: Internet is using 70-75% of battery after firmware update
    Do the hard reset, then let us know.
  3. #3
    same issue here
  4. #4
    My battery life suffered a bit after update as well...came from rezound so it was still great by comparison. Lol!! Did hard reset last night...battery is back to fantastic status so far today:-D
    Sent from my HTC6435LVW using Android Central Forums
  5. #5
    Does anybody know if the hard reset worked. I'm having the same problem..
  6. #6
    Daniel.Lynch's Avatar
    Posts
    Carrier
    CM10.2
    You know what, I didn't think to check what made my battery die yesterday, but I pulled it off the charger at 9 AM, and barely even TOUCHED the phone all day because I was at work, and when I went to make a call at 7 o'clock, it died mid call!! What the hell! My phone lasts longer than that even with heavy use regularly! Today it seemed to be going down pretty quickly, but not as fast as yesterday. Crazy. How do I do a hard reset on this phone?
  7. #7
    I'd like to know how to do a hard reset as well. Also, if I do a hard reset, do I lose any data/information on my phone?
  8. #8
    alcor34's Avatar
    Posts
    Global Posts
    354 Global Posts
    Quote Originally Posted by eisenhulk View Post
    You can hard reset under backup and reset in settings. Otherwise in recovery from power down. Yes you'll lose all data and settings if you don't have restore checked for basic settings. You can choose not to loose pics and other media but i've never tried to see if it actually works. I'm contemplating a hard reset myself as this is annoying.
  9. #9
    I've been running into the same issue.
  10. #10
    Jennifer Stough's Avatar
    Retired Moderator
    Posts
    Global Posts
    2,034 Global Posts
    Not for me. Internet is normally always one of my top apps, but never over 20%
    Sent from my Verizon Droid DNA
    Attached Thumbnails Attached Thumbnails Internet is using 70-75% of battery after firmware update-uploadfromtaptalk1367641340168.jpg
  11. #11
    I performed a little experiment last night and fully charged my phone, restarted it, and put it into airplane mode overnight. Sure enough, the battery dropped to 80%. The culprit:
    It looks like the browser is having some aberrant activity. I would do a factory reset today, but my laptop died yesterday and I'm away from my desktop.
  12. #12
    Retired Moderator
    Posts
    Global Posts
    2,034 Global Posts
    Quote Originally Posted by Infinite Jest View Post
    That is so weird... Have you tried clearing the cache for internet? May not help, but it is worth a try before doing a factory reset.
  13. Thread Author  Thread Author    #13
    I did the hard reset, and my battery issue is gone! I now am back to normal with great battery life! I know a hard reset can be a pain, but it was worth it for me!
  14. #14
    Quote Originally Posted by rstripes72071 View Post
    Do you mean a factory reset?
  15. Thread Author  Thread Author    #15
    Yeah, sorry about that. I should have worded it better...
  16. #16
    It's no problem, I just wanted to be clear if it actually helped you. I'll give this a shot tonight.
  17. #17
    Did it work? I'm having the same issues Click image for larger version.
Name:	2014-02-19 04.54.39.png
  18. #18
    I think I solved the issue! I discovered it here. The problem is with sync in your google account. I just turned mine off completely but there's more detailed instructions on how to fix it. Go to Settings>Accounts>your Google account and turn off browser. Problem solved instantly!
    NicoleB83 likes this.
  1. Is the OS supposed to be using a lot of battery life?
    By 2010BmwM3 in forum Verizon Galaxy Nexus
    Last Post: 12-21-2011, 05:30 PM
  2. Facebook for Android is using a ton of GPS time
    By aviduser in forum Android Apps
    Last Post: 11-15-2011, 12:27 PM
  3. Powering my TB off an on uses a LOT of battery
    By MojaveHigh in forum Verizon HTC Thunderbolt
    Last Post: 04-22-2011, 08:54 AM
  4. 60 to 75% of Battery Life being used by Display.
    By Obmutescence in forum HTC EVO Shift 4G
    Last Post: 01-24-2011, 01:24 AM
  5. Cell Standby and Phone Idle using a lot of battery
    By splmonster in forum HTC EVO 4G
    Last Post: 06-13-2010, 03:33 PM
