This is a ROM I made for myself and shared it a few days ago, at another site (shhh!).
It's a ROM that joelZ9614 released but pulled due to a problem with it flashing.
I simply got it to flash, deodexed it, removed unless Verizon and HTC apps and added crpalmers kernel.
This is the 2nd version that's less aggressive on removed apps, (I missed TV!) but it is pure.
i.e. No themes, no extra apps, no EQS. Xposed Framework installer is included and I'd recommend using it and the MoDaCo ToolKit to tweak the system to your liking.
This "update" has the tweaks I've done to my system and I think anyone that tries will like.
I'm a n00b and messed up the init.d settings I wanted to stick. It's good out the box but here's my recommended settings:
Using TricksterMod:
Read Ahead Buffer Size: 384
Scheduler: deadline
Advanced Control:
fifo_batch: 8
read_expire: 30
write_expire: 250
writes_starved: 1
Governor: conservative
Governor Control:
down_threshold: 30
freq_step: 25
sampling_down_factor: 5
up_threshold: 30
Multicore Power Savings: 2
Everything is working but Zoe, of course, and Panorama sweep.
This is for Verizon only. It's been reported that MMS will not work on GSM.
Thanks go to joelZ9614 for the ROM, crpalmer for the kernel, and zepplinrox for the supercharging.
Link: http://www.adrive.co...nse5_070413.zip
md5:d9dc74de1ed3d78005391166562ee655
Using TricksterMod:
Scheduler: deadline
Advanced Control:
fifo_batch: 8
read_expire: 30
write_expire: 250
writes_starved: 1
Governor Control:
down_threshold: 30
freq_step: 25
up_threshold: 30
