09-06-2014 01:17 PM
43 12
tools
  1. David Brinkley's Avatar
    I was using my Navigation feature yesterday that came with the phone. This morning I get up in the morning and the icon is not on my rolling list of Icons and Apps. It has disappeared and when I search I cannot find it. How did it disappear?
    07-12-2013 08:53 AM
  2. Va1ha11a's Avatar
    I believe that this was a part of the new google maps update, and that navigation can be found inside Google Maps.
    07-12-2013 09:12 AM
  3. jf2go's Avatar
    Yep, same here. With the update, Navigation is no longer a separate icon in Maps either - no separate icon in my Apps drawer, and no direct access in Maps. It looks like you have to type or say the destination in Maps, then select your preferred route, then you are offered a "Start" for turn-by-turn navigation at the bottom. Fortunately, it looks like you can do everything through Google search. You can say " navigate to Disneyland" and it takes you directly to turn-by-turn navigation. I would like the direct access icon back though.
    07-13-2013 05:31 PM
  4. Obed Toro's Avatar
    no it can't you musta really know what you're talking about Google are a bunch of freaking retards
    07-15-2013 10:30 PM
  5. Obed Toro's Avatar
    I lost my icon assumed that my son erase my GPS so I went ahead and reset my phone. and had one hell of a time jailbreaking it thanks for those assholes Google
    07-15-2013 10:31 PM
  6. Lizz Nieves's Avatar
    All you need to do is uninstall the update ny going to settings then applications then scroll thru list till you get to Google maps then click it then click uninstall updates and the navigation icon will come back nine of your addresses will be there. I did it. Very happy its back.
    Troy Vink and NancySood like this.
    07-16-2013 10:07 PM
  7. cdmta's Avatar
    Sounds like misdirected anger. Or previous iPhone user.
    07-17-2013 10:54 AM
  8. wxrusss8's Avatar
    "Jailbreaking"? This isn't an iPhone. And why would you need to do that anyways? I think your a bit confused.
    07-17-2013 11:15 AM
  9. 1dtbrown's Avatar
    I just put the map icon where the navigation icon was, works fine. Google seems to have remembered lots of my destinations. No problem adjusting to a new App version it just seems better to me.
    Your Smartphone is only as Smart as you are
    07-17-2013 07:59 PM
  10. Kevin Palmer1's Avatar
    Thanks this fixed my problem! Awesome
    07-19-2013 12:17 PM
  11. Kelly Hyatt Masters's Avatar
    Thank you so much!
    07-20-2013 09:57 AM
  12. Troy Vink's Avatar
    Thanks Lizz!! Made my life happy again, until another update push. Is there a way to turn off the updates for this specific application?
    07-21-2013 11:06 PM
  13. Sheri Wood's Avatar
    I uninstalled the maps updates and my navigation icon is back! Very easy. Thank you!
    07-25-2013 04:09 PM
  14. Daniel.Lynch's Avatar
    I'm confused as to why some of you want the navigation icon, when the navigation is now fully integrated into Google Maps?
    07-26-2013 10:27 AM
  15. streetstrip01's Avatar
    They hang out with the same person who does a factory reset when he can't find an app.
    07-26-2013 11:42 AM
  16. Jennifer Stough's Avatar
    I haven't undone the update, but I personally preferred the navigation icon as it was more convenient to me to press the navigation button, Google voice, and navigate. Opposed to maps, navigation, destination, Google voice, navigate. And I just haven't gotten the hang of long press home button, Google voice, Google navigate to address, and navigate.
    Sent from my HTC6435LVW using AC Forums mobile app
    07-26-2013 11:53 AM
  17. garublador's Avatar
    FWIW, it looks like the latest, latest version of Maps gives you the "Navigation" and "Local" icons back.
    07-26-2013 12:28 PM
  18. KSDroid01's Avatar
    I use Nav all the time, Maps rarely. It's an extra unnecessary step to open Maps, then hit the navigate button. Virtually zero benefit to me to have them integrated.
    mightyfacundo likes this.
    07-26-2013 09:44 PM
  19. Daniel.Lynch's Avatar
    I touch the Google now mic button, say "navigate to 'destination'" and its done lol
    Sent from my HTC6435LVW using Tapatalk 4 Beta
    07-29-2013 02:22 AM
  20. Jennifer Stough's Avatar
    I don't have a google now or Google search widget on my page. In fact, I don't use Google now, it's disabled. So I have to long home press>voice button>speak address>click navigate compared to the previous click navigation>voice button>speak address>navigate. It's relatively the same amount of steps, I just have to get accustomed to it.
    07-29-2013 07:00 AM
  21. Daniel.Lynch's Avatar
    May I ask why you don't use Google Now? I've grown to love it, its sped up my phone usage exponentially.
    07-29-2013 11:57 AM
  22. Jennifer Stough's Avatar
    I just haven't gotten around to it, lol. I turn off all features on my phone that I don't use, and turn them on when I need them. Google now just isn't one I have needed.
    07-29-2013 12:50 PM
  23. Daniel.Lynch's Avatar
    Oh man, you gotta give it a try!
    07-29-2013 01:48 PM
  24. KSDroid01's Avatar
    I actually like it a lot but sometimes it gets a little creepy: Google Now goes into my email, reads my airline itinerary, pops up a reminder card to tell me that it is time to leave for the airport, along with a suggestion that I Nav the route; pops up another card with my airline flight, gate, and on - time status; then pops up a third card with weather at my current location AND my destination city! And we thought Big Brother was going to be the government...!
    07-29-2013 07:21 PM
  25. Idahamad Hamad's Avatar
    need my navagation
    - - - Updated - - -
    lost my navagation
    08-01-2013 06:13 PM
43 12
  1. Little Bit Of Help Needed With My One X
    By Joshua Falls in forum HTC One X
    Last Post: 07-15-2013, 11:54 AM
  2. Android for Beginners: How to Avoid Trojans on your Smartphone
    By mlauzon in forum General Help and How To
    Last Post: 07-13-2013, 01:24 AM
  3. Replies: 1
    Last Post: 07-12-2013, 08:54 AM
  4. com.android.phone crashes when using sms
    By tabmow in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 07-12-2013, 08:03 AM
  5. Replies: 0
    Last Post: 07-12-2013, 07:37 AM
