1. hannsoft's Avatar
    I'm "between updates" ... meaning, I've gotten the first small 14MB one but not the big mama. Now, whenever I plug my phone into the charger, I get the little message and "!" icon on the notif bar telling me that charging with the charger I'm using will go very slowly, that I should use the one that came with the phone.
    Um. This IS the one that came with the phone.
    Yet my Oregon Scientific wireless charger generates no such message. Strange!
    12-10-2013 08:39 AM
  2. doctorg23's Avatar
    I started experiencing this problem a few months ago. It is a hardware issue, not a software issue. It usually means the charger is not making good contact with the phone.
    There are other threads about ways to bend the pins, etc, etc.
    I've found that just tweaking the way the charger sits in the bottom of the phone. I even noticed when this happened recently that the USB portion of the charger had come loose from the actual plug portion of the charger. I pushed the USB cable back in tighter and voila all is well. Hope this helps.
    12-10-2013 11:17 AM
  3. hannsoft's Avatar
    Very interesting! I'll give all those thoughts a shot - thanks!
    Sent from my Nexus 10 using Tapatalk 4
    12-10-2013 03:35 PM
  4. luke31's Avatar
    I can second that. I stepped on the charger at work a few weeks ago, and bent the pins on the actual charger. I also got that slow charging notification afterwards. I plugged in the USB cable from my nexus 7 into the HTC AC Adapater, and everything is perfect now
    12-11-2013 07:22 AM
  5. jrwatson's Avatar
    My original charger started doing that a few months in, when I charged my phone on my bed. I think it's just a fragile charger. Since then, I've been using my Nexus 7 charger with my phone, and despite all the stress I put it through, it still works great.
    12-16-2013 02:07 PM
  1. Phone won't turn on, white LED blinking
    By ducow in forum Google Nexus 4
    Last Post: 04-18-2017, 01:05 PM
  2. kp is stopping in my head phone
    By usguyver in forum AT&T Samsung Galaxy S4
    Last Post: 12-12-2013, 06:14 PM
  3. need new phone, may switch to android
    By brick58 in forum General Help and How To
    Last Post: 12-11-2013, 02:32 PM
  4. Phone not working - should I root?
    By Mari Pereira in forum General Help and How To
    Last Post: 12-11-2013, 12:39 AM
  5. Moto g as a stop gap phone?
    By RavenSword in forum Moto G (2013)
    Last Post: 12-10-2013, 08:23 PM
