Home screen not going into dock mode after update...
phoenixone
363
30
My wife's and my phone home screen are not going into dock mode (just the home screen not auto rotating) using iBolt car dock after the recent update. Anyone else with the same problem? Solutions?
Thanks.
This may sound silly, but do you have auto rotate checked in the pull down settings menu?
I don't know. I don't have a dock with a magnet that activates the car mode, but I did use an app called QuickShortcutMaker to make shortcuts for both the car mode and dock mode. Once in the respective mode, they rotate depending on the orientation of the phone.
Edit: only the car mode rotates. The dock mode does not auto rotate.
Thanks Mikey. Still puzzled because it was working fine before the update and now since the update, it's borked.
Osivourough
