Results 1 to 4 of 4
    Default There is a hole next to earphone jack on the top
    What exactly is it? I never noticed that there was a hole on the top until I mistakenly prodded it with a needle thinking that it was the sim card tray. I thought it might be a mic but the mic is on the bottom. So what's the hole doing there on the top next to the earphone jack and what exactly is it? I'm also worried that I plugged a needle in it, not too hard, but still worried that i might have damaged something -__- Can anyone tell me?
  2. #2
    talonsmith's Avatar
    Posts
    Global Posts
    107 Global Posts
    ROM
    Stock
    Default Re: There is a hole next to earphone jack on the top
    Its the noise cancellation microphone
    What does it do?
  4. #4
    UJ95x's Avatar
    Posts
    Global Posts
    5,531 Global Posts
    ROM
    Slim Kat 4.4.2 Build 3
    Cancel out other sounds while you're making a phone call so that the other people can hear your voice well
    Everything in this post is 100% accurate...I think
    R.I.P. Motorola...and what could have been the best smartphone line ever
  1. No Network (needed to restart phone)
    By hell911 in forum Google Nexus 5
    Last Post: 12-19-2013, 01:38 PM
  2. Reference to icons in my notification bar?
    By Steve Finkelstein in forum HTC One
    Last Post: 12-18-2013, 08:10 PM
  3. Play store wont download apps on new S3
    By Xandra Kay in forum Android 4.0 Ice Cream Sandwich
    Last Post: 12-17-2013, 10:52 PM
  4. Having some trouble enabling USB debugging on a Nexus 7 with broken digitizer.
    By Pieface Bear in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-17-2013, 05:54 PM
  5. Replies: 2
    Last Post: 12-17-2013, 05:40 PM
B
