Results 1 to 8 of 8
    bgoldenberg94's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Problems With Full Screen Ads?
    Hello all,
    I'm new to AC (this being my first actual post) and I'm here to ask if anyone else gets full screen ads on their phones. I've run a bunch of virus scans and nothing seems to come up, and I've uninstalled nearly every app that I think could've been the source of the problem (even GO SMS). I'll post a screenshot as an example of what I'm seeing every hour or two. Thanks for any help.
    Attached Thumbnails Attached Thumbnails Problems With Full Screen Ads?-spam-screenshot.jpg
  2. #2
    mightyfacundo's Avatar
    Posts
    Global Posts
    1,623 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Problems With Full Screen Ads?
    Try installing Air Push Detector. It should be able to tell you which app is generating the ads. When the prompt pops up telling you that you don't need the app, just click "It doesn't work" to force it to run.
    Sent from my HTC6435LVW using AC Forums mobile app
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'll check it out and get back to you, thanks for the recommendation.
    Update: Downloaded the app, said that "I couldn't find any apps with notification ads".
  4. #4
    Posts
    Global Posts
    1,623 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Weird. Would you mind trying Lookout Ad Network Detector? Let me know if it works for you.
  5. #5
    Shawn_S's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also try Norton mobile and Norton Spot.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did nothing for me.
    - - - Updated - - -
    I'll check it out, thanks.
    It says some apps that I could uninstall, but it doesn't say what app causes the full screen ads.
  7. #7
    Shawn_S's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bgoldenberg94 View Post
    Did nothing for me.
    - - - Updated - - -
    How many apps is it? Delete them one at a time to find the culprit.
  8. #8
    nickyboyparks's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I found a solution. When the ads pop up. Hit your home button for few seconds to view resent apps if using 4.2 android or whatever technique to see recent apps.
    You should see the ads along with recently used apps and the ads are generated by " network service" . go into settings-apps-all apps-scroll to network service and disable or deactivate. It will work. I had the same problem.
    I believe it's malware but haven't investigated further why it happen. I will email Google on the issue..
  1. Frustrated with group messaging!!
    By Derek Schomer in forum Verizon HTC One
    Last Post: 01-09-2014, 08:48 AM
  2. Changing SIM causes problems with apps
    By Stuart Jackson in forum General Help and How To
    Last Post: 01-08-2014, 12:58 PM
  3. If lag is a problem you have a defective tablet...
    By robbielyn in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-08-2014, 06:21 AM
  4. Quizno's ad in my gallery?
    By pmaisonet in forum Samsung Galaxy Note 3
    Last Post: 01-07-2014, 06:23 PM
