1. hmfoster's Avatar
    Has anyone found an app that will turn off the phones speaker when you turn on the bluetooth.? It would be nice so that the people around you will not hear the ringtone or other announcements of incoming calls or messages.
    Thanks
    Harvey
    03-16-2014 03:56 PM
  2. B. Diddy's Avatar
    That sounds odd--if you're using a Bluetooth headset for a call, then the external speaker should automatically deactivate anyway. Notification tones should come through the Bluetooth headset. Is that not happening?
    03-17-2014 12:40 AM
  3. disneyf1's Avatar
    I have had intermittent issues with that for a while. The firmware update helped a lot, but I still have issues when using an A2DP BT set. Non-A2DP sets seem to work fine.
    03-18-2014 10:45 AM
  4. hmfoster's Avatar
    Yes the phone call come only through the bluetooth but all the notices come through both.
    What non a2dp bluetooth worked but does it still announce to the bluetooth ?
    Thanks
    Harvey
    03-19-2014 03:27 PM
  5. disneyf1's Avatar
    I don't have mine set to announce so I don't know about that. the headset I use now was free with the purchase o my wife's BT visor unit and that only cost $20! So this is a VERY cheap BT headset. It works and the $100 Jawbone I bought (one of four different expensive sets that don't work) doesn't. go figure...
    03-24-2014 10:12 AM
  1. Bluetooth Tethering FoxFi from Moto X on 4.4.2
    By 4GLTE Lover in forum Moto X (2013)
    Last Post: 05-24-2014, 11:48 AM
  2. Replies: 6
    Last Post: 03-18-2014, 04:10 AM
  3. I could use some major help
    By zomgsandisk in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-17-2014, 02:03 PM
  4. How do I turn on app notifications when on the data network?
    By Josh28 in forum General Help and How To
    Last Post: 03-16-2014, 11:28 AM
