I just swapped the guts of my Droid DNA over to a new case and upon putting it back together and hooking it up, I plugged in the charge cable and tried turning it on, and it vibrated once and turned off.
From that point, I've not been able to get an indicator light, no blinking LEDs, no sign of life, and to boot, the Battery was drained before I took it apart.
I've had it plugged into the wall for about 20 minutes now, hoping it would show some life, but nothing. It was starting to heat up, as these phones usually do while charging, but now, nothing.
I reseated all of the cables, no avail.
I'm wondering if it could be a dead USB port, or maybe the battery was so drained that it just died.
Is there any advise for bringing something like this back to life, or a way to link it to my PC to bring it back?
Or even a way to delete the data so I can get rid of it without worry of my data being used?
