1. TitaniumMan's Avatar
    My boss just got a new incredible 2 but it makes a tone after the unlock screen, how you disable that? I looked for it and could not find anything.
    07-21-2011 09:19 AM
  2. jobjohnny's Avatar
    Tap the weather on the home screen. Go into Settings, uncheck Sound Effects.
    mbmali and rahul325 like this.
    07-21-2011 10:58 AM
  3. mbmali's Avatar
    You are a genius....thank you!!!
    01-12-2013 11:31 AM
  4. dobermans rule's Avatar
    Go under setting-sound- and uncheck the lock sounds
    Sent from my Droid Incredible 2 using Android Central Forums
    01-12-2013 01:01 PM
  5. rahul325's Avatar
    08-07-2015 12:05 PM
  6. rahul325's Avatar
    OMG!!! this has been bothering me for 24hours!!! you Sir are a GENIUS!!!!!!
    08-07-2015 12:07 PM
