1. kirksucks's Avatar
    The last thing I did was uninstall a wallpaper app I didn't like via settings/apps. It didn't uninstall it but it uninstalled my whole settings application. Is there a way to fix this without a hard reset?
    Sent from my DInc2 via Tapatalk
    09-26-2011 06:31 PM
  2. Vudumedic's Avatar
    No probably not. I would suggest that it may be more of a coincidence that cause and effect. Have you installed the most recent firmware upgrade? I'm wondering if the same hole in the coding that was causing system apps to disappear on the original Gingerbread update is still present in the new upgrade.
    09-26-2011 08:51 PM
  3. kirksucks's Avatar
    I'm running 2.3.4
    Took it to vzw and they reset it... Again.
    I kinda went on an app spree today so it's likely that I got some funky app
    Sent from my ADR6350 using Tapatalk
    09-26-2011 11:45 PM
