Results 1 to 6 of 6
- 10-26-2011, 05:58 PM
Thread Author #1
Droid Inc 2 Not reading SD Card?
Hi all,
So I woke up this morning to a very different sounding alarm than usual, and thought that was weird. Then people called me, and the ringtones were all different. Then I took some great pictures (autumn in Maine, amazing!) but they're not anywhere on my phone.
When I try to access the pictures from the camera, I get a message that says "No photos or videos found!" Then when I try to change my ringtone, I don't get the full list, it only says "Default Ringtone."
I checked to see if the SD card was in, which it was. Phone says that there is 13.45gb left on the card, so there is room, and it does recognize my sd. But where are all my pictures and ringtones?!
Has this happened to anyone else? Any help would be appreciated! - 10-26-2011, 07:04 PM #2
Re: Droid Inc 2 Not reading SD Card?
I had to take out the SD card and factory reset my phone
- 10-26-2011, 07:09 PM
Thread Author #3
- 10-26-2011, 08:33 PM #4
- 10-27-2011, 07:59 AM #5
I had that happen to me once. I simply took the card out and connected it to my computer. The computer should see all of your files just fine. I copied all of the cards content to my PC, formatted the card, and then copied the data back to the card. I put the card back into the phone and everything worked perfectly again. I would try that first.
- 10-27-2011, 08:37 AM #6
Yeah, as stated above, I don't think you need to resort to a reset. Flash memory is very unstable memory. It's not uncommon for SDcard memory to become corrupt. I see it all the time at work.
Backup your files on your computer and reformat the card.
Reply
