DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 19 of 19
    Default keyboard problem
    Hello guys, I am really happy to find this community, congratulations to all of you.
    I am here because I need your help on a htc verizon incredible 2. My problem is that the space, dot and comma keys are not working right. Some times they work when touching them but the majority of the time does not work. So at this moment I can not write any SMS messages or e-mails.
    Just in case I need to give more info:
    Androide version 2.3.4
    HTC sense version 2.1
    Software # 4.08.605.3
    I would really appreciate your support.
    Thank you.
  2. #2
    Vudumedic's Avatar
    Posts
    ROM
    RunnyMik/stock
    Default Re: keyboard problem
    Is it just the keyboard you are noticing problems with? I mean are the keys not working on both portrait and landscape view or just in one? Are you having trouble selecting things in that area of the screen when on the home screens or the app drawer? Have you tried any of the alternative keyboards out there? I would recommend trying thumb keyboard and try a few different layout combinations and see if that fixes the problem.
  3. #3
    djaquez21's Avatar
    Posts
    ROM
    One XXX RLS 6.0.2
    Default
    Sometimes I would have problems with my keyboard where it wouldn't let me press the "v" key.. A simple reboot would fix it. Don't know why it happens though.
    Quote Originally Posted by Vudumedic View Post
    1.This happens on portrait only. I have tried what you suggested "landscape" and it works without any problem.
    2. No, I am not having problem selecting things in that area. Only for portrait massages.
    3. Alternative keyboard: I have tried in compact and phone mode still the same problem in that specific place.
    Quote Originally Posted by djaquez21 View Post
    Nope, I have tried this and I still have the same problem.
    What else can I do guys?
    what about if I reinstall the phone's software or update it? Would that make the difference?
  7. #7
    Default
    By alternative, did you download any keyboard apps from the market.
    Sent from my ADR6350 using Tapatalk
  8. Thread Author  Thread Author    #8
    No that I recall. I have checked in "All applications" and I don't see anything related to third party keyboard app.
    I am getting frustrated. Its very inconvenient and unpleased for me writing everything on landscape mode
  9. #9
    He's suggesting that you download a different keyboard app from the market and see if you have the same problem with it.
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by socarwolverine View Post
    Correct, my bad sorry guys. I will try that in a moment and write back. thanks
  11. #11
    Default
    Suggestions, SwiftKey(what I use. Not free but worth it), Swype, GoKeyboard. Some others mentioned in previous posts.
    There's a bunch, search the market and read reviews.
  12. Thread Author  Thread Author    #12
    Guys you are awesome. Sorry for my late feedback. I installed SwiftKey X and it works very good I am able to use the phone in portrait mode "all keys". I really appreciate all your help. I'm finally happy. On the other hand, I wonder what is the problem with its default keyboard app.
    @kirkiscool, yes is around 3.99 or so, but I am in trail version and after the month I guess I will buy it. thanks.
  13. #13
    Default
    Glad I could help
  14. #14
    Glad it worked out. I've used stock, swype, and swiftkey x, and swiftkey is by far my favorite keyboard. Once it learns your typing habits it can literally predict an entire sentence.
  15. #15
    jasongom's Avatar
    Posts
    Global Posts
    5 Global Posts
    I been having similar problems with certain keys not working. For me its in landscape mode and its prevalent in all my keyboard apps (touch, touchpal, korean keyboard, google ics keyboard, sine, etc) and its usually the "s" that is not working...any thoughts?
  16. #16
    +1 for SwiftKey X.. Awesome keyboard replacement.
  17. #17
    bunjy's Avatar
    Posts
    Global Posts
    204 Global Posts
    Default
    I love SwiftKey. It's the best on the market.
    Sent from my Droid Incredible 2
  18. #18
    Default
    Swiftkey is the best. Its free i believe. You pay when you keep the suggestions on after your 30 day trial. Well worth it tho! I have zero reasons to go back to blackberry because of Swiftkey
    Sent from my DInc2 using Tapatalk 2
  19. #19
    Hello, I had the same problem and i found that multi-touch keyboard had a conflict with a background app, in my case was youtube y wiped youtube's data and removed updates and now im using an earlier version of youtube. and keyboard now responds
