Results 1 to 8 of 8
    Default Capacitive buttons won't light up.
    Has anyone else had this problem? If so can I do anything to fix it besides filing an insurance claim?
    Sent from my Dinc2 using Tapatalk 2
    All tyranny needs to gain a foothold is for people of good conscience to remain silent.
    -Thomas Jefferson-
  2. #2
    swenpro's Avatar
    Posts
    Global Posts
    176 Global Posts
    Default
    Sorry, haven't had any such or other issues with my Dinc2
    Sent from my ADR6350 using Tapatalk 2
  3. #3
    johnjuan's Avatar
    Posts
    Global Posts
    14 Global Posts
    Default Re: Capacitive buttons won't light up.
    my buttons stopped lighting in portrait mode for a few hours then started working again. I would try manufacturer's warranty if possible. Good luck.
    update... My screen display went out completely! Went to verizon hoping to get Htc warranty but she said because of scratches on the case i'd have to use insurance. I could still receive calls becauseI knew where to swipe to answer. When I called Asurion they issued manufacturer warranty. Btw in direct sunlight I could barely see screen. But capacitive buttons where ok.
  4. #4
    Do they still work, even though they are not lit?
    Have you tried playing with the brightness? Could it be that the display has just auto-dimmed to the point where the buttons just seem like they went away?
    I'd try turning the brightness to 100% and see what happens
    Default
    Update: The capacitive buttons just started working again. No clue what that was all about.
    -Thomas Jefferson-
  6. #6
    I thought I had the same problem until I went in a dark room and then I could see the buttons lit up or turn up your brightness
  7. #7
    snsethy's Avatar
    Posts
    Global Posts
    93 Global Posts
    Quote Originally Posted by johnjuan View Post
    My screen/buttons have been doing the same thing, I kept messing with it until it the screen turned on, but it's kind of jacked up. Now I wish I had left it broken. Although Verizon has in the notes that there are bright lines on one side and dark shadows on the other from the half second after I replaced the battery and powered up.
  8. #8
    sjpritch25's Avatar
    Posts
    ROM
    MIUI 1.11.4.1
    Quote Originally Posted by MrGr8 View Post
    The only time that was happening was with the custom ICS ROMs. Do you have one of them installed or are you stock.
    Droid Incredible 2 (S-OFF)
    Android Version 4.2.2
    Evervolv-Conor-3.2.0-Nightly-2013.05.05
    Kernal 3.076-evervolv nightlies
    Oc 1.4mhz
