1. Black_Robin's Avatar
    So a while back one of my friends calls me and I don't get to it in time so I miss the call, I'm on my way to my girlfriends and she tells me this random number called. Turns out it was the friend that called me. I was confused so we started expirmenting and apparently whenever someone calls me and I don't answer, it will start ringing again but go to my girlfriends phone. Not sure why this happens and if she calls me and I don't answer , it'll go to her voicemail. Explination?
    Sent from my ADR6350 using Android Central Forums
    06-10-2012 11:55 AM
  2. DroidDev's Avatar
    Are both of your phones set up on the same account? If that is the case then call fowarding has been set up some how.
    If not then perhaps an app is doing it. Do you use Google Voice? Those are the only two ways I believe you can do Call FWDing.
    06-10-2012 04:55 PM
  3. Black_Robin's Avatar
    No we seriously have never messed with eachothers accounts and I've never put her number into my phone other than as a contact and it happened really randomly one day, nothing had happened the day before or anything so I have no idea how it came about. And i have a rooted device so I've reset my phones hundreds of times so even if it was an app, I've deleted stuff off my SD card too.
    06-10-2012 10:32 PM
  4. Black_Robin's Avatar
    And she isn't techy at all (she breaks electronics just from looking at them like seriously) so I know she didn't do it herself
    06-10-2012 10:34 PM
