Results 1 to 3 of 3
    Default Am I using Wifi?
    Hi everyone -
    I'm new to having a smart phone and I just got an Incredible 2. I have a question about wifi. If I'm connected to a wifi network am I automatically using wifi instead of data or is there something else I need to select?
    Thanks for the help!
  2. #2
    DroidDev's Avatar
    Superstar Status
    Posts
    Global Posts
    689 Global Posts
    ROM
    AOKP M5 / Franco
    Default Re: Am I using Wifi?
    Hi Joribox!
    When your phone is connected to a WIFI access point, be it a home router, or a public access point it will look to that connection first before using Mobile Data.
    If you are connected to Wifi then your phone will not be using Mobile Data to put it another way
    DD
    Look at your comment. Back to mine. Back to yours NOW BACK TO MINE. Sadly, it isn't mine. But if you stopped trolling and started posting useful replies it could LOOK like mine. Look down, back up, where are you? You're scrolling through comments, finding the ones that your comment could look like. Back at mine, what is it? It's a highly effective counter-troll. Look again, MY COMMENT IS NOW DIAMONDS.Anything is possible when you think before you comment or post. Im on a computer.
    Thanked by:
    Right on Thank you for the quick reply!
