HTC Incredible 2 Boot Loop after hard reset Help!!!!
Redfire_
I recently did a hard reset on my HTC Incredible 2, now its stuck in a boot loop, I also can not access Hboot by holding the power button and down volume on boot.
Do I have any options? Is there anyway to reinstall the factory rom or can I root the phone to fix this? The phone is completely factory now it's never been rooted.
Thanks for any help!
Chris
anon(354569)
58
3
Chris
If you aren't rooted, I would just pull the battery out for about 30 sec and then put it back in and attempt to do a normal power up.
Chandrakant Shirsat
My HTC Desire SV get switch off while playing game & after that when had tried to charge & start it, it?s not booting, The LED orange light is also continuously blinking while charging.
Pls help or suggest what to do
wei34
