Results 1 to 6 of 6
    Default HTC Incredible 2 Boot Loop after hard reset Help!!!!
    I recently did a hard reset on my HTC Incredible 2, now its stuck in a boot loop, I also can not access Hboot by holding the power button and down volume on boot.
    Do I have any options? Is there anyway to reinstall the factory rom or can I root the phone to fix this? The phone is completely factory now it's never been rooted.
    Thanks for any help!
    Chris
  2. #2
    jab0321's Avatar
    Posts
    Global Posts
    92 Global Posts
    Default Re: HTC Incredible 2 Boot Loop after hard reset Help!!!!
    Quote Originally Posted by Redfire_ View Post
    Chris
    If you aren't rooted, I would just pull the battery out for about 30 sec and then put it back in and attempt to do a normal power up.
    Redfire_ likes this.
    Thanks for the suggestion, I should have mentioned I have already tried that several times....
  4. #4
    jab0321's Avatar
    Posts
    Global Posts
    92 Global Posts
    Hmm, not sure what to suggest then since you aren't rooted. I'm not sure of a way to reinstall the factory ROM without root. If you can't send it back or get it replaced I would try rooting it and then you should be able to get things going. This is the method that I used: [GUIDE] Comprehensive S-OFF/Root Methods - xda-developers
  5. #5
    sjpritch25's Avatar
    Posts
    Carrier
    MIUI 1.11.4.1
    I'm not sure what version of android your on, but here is a thread that has signed RUU's. [RUU] HTC Incredible 2 Signed RUUs (PG32IMG.zip) - Droid Incredible 2 / S - RootzWiki
  6. #6
    My HTC Desire SV get switch off while playing game & after that when had tried to charge & start it, its not booting, The LED orange light is also continuously blinking while charging.
    Pls help or suggest what to do
  1. Help Suck on White HTC Incredible Boot Screen!
    By Gatchaman2025 in forum Verizon Droid Incredible
    Last Post: 07-09-2012, 09:14 PM
  2. Boot loops after installing Wallet, help!
    By wallyweaver in forum Verizon Galaxy Nexus
    Last Post: 12-19-2011, 12:39 AM
  3. Replies: 7
    Last Post: 08-03-2010, 06:20 PM
  4. Please help: Need to recover after hard reset
    By rockhead11 in forum HTC Hero
    Last Post: 06-15-2010, 02:31 PM
  5. Battery life DRASTICALLY improved after Hard Reset!
    By richcracker in forum HTC EVO 4G
    Last Post: 06-08-2010, 06:34 PM
