Have you tried on WiFi, does GMail and Google Play work via WifI ? If you are trying to connect to the internet via a German cell provider, you may need to set the APN for that service. You can check with the provider to see what their APN settings are, but if you can get on Google Play via Wifi, there are some apps for that. Check SIM APN.
HTH
JohnT
