DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 3 of 3
    Default Unlocked Droid Incred 2 Out of country problems
    I just unlocked my Droid for use in Germany. Calls and text works fine. But can't download apps or access my gmail account. Help please?
  2. #2
    jtruchon's Avatar
    Posts
    Global Posts
    15 Global Posts
    Default Re: Unlocked Droid Incred 2 Out of country problems
    Have you tried on WiFi, does GMail and Google Play work via WifI ? If you are trying to connect to the internet via a German cell provider, you may need to set the APN for that service. You can check with the provider to see what their APN settings are, but if you can get on Google Play via Wifi, there are some apps for that. Check SIM APN.
    HTH
    JohnT
    Nope, not working with wifi either. If I try to get an app it comes off as my old phone and won't let me get it on the droid.
  1. Help! out of the country, time and date problem...
    By DivaButterfly in forum Virgin Mobile Optimus V
    Last Post: 09-23-2012, 08:02 PM
  2. Traveling out of country - is there a way to turn off Data?
    By jaymzb0nd in forum Samsung Galaxy S3
    Last Post: 08-14-2012, 04:59 PM
  3. Traveling out of country.
    By BigCrisco39 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 05-13-2012, 09:13 PM
  4. Original Droid (Officially Out Of Stock)
    By callofduty4 in forum Motorola Droid
    Last Post: 08-12-2010, 11:55 AM
  5. Verizon is out of Droid phones until mid July?
    By BleezyD in forum General News & Discussion
    Last Post: 06-29-2010, 07:47 PM
