- 07-11-2011, 11:58 PM #151
Re: Battery life thread
I just went through a 17 hour day of moderate use and started my charge with 35% battery life remaining. Not as good as some others are reporting, but getting through a full day like this is good enough for me. The phone is still relatively new and I'm hoping that it will get better with time.
- 07-12-2011, 07:04 AM #152
I feel as though mine is. I can pretty much always make it through a day now, I didn't use the phone much yesterday but I was at 40% when I plugged it in and Sunday when I used the phone even less I was at 70%.
But for me an extended battery will be needed if I keep this phone. During a phone intensive day, I feel there will still be problems as 40% after what if light use for me, isn't great. Has anyone tried any of the extended batteries that fit with the stock door? The 1750, 1800, or 1900? I was thinking of giving the chichitech 1900 battery a try as it has gotten good reviews. However it just seems like one of those too good to be true things. I dunno why HTC wouldn't wanna put the largest possible battery in their phone that would fit right from the factory.
Link for chichitec 1900 battery: Sprint HTC EVO 4G 2x1900 mAh Battery Longer life than OEM+Wall Travel Dock USB Charger for EVO Shift 4G,Verizon Droid Incredible 2, Touch Pro2, myTouch Slide, Google DesireZ, G2 by CHICHITEC ONLY:Amazon:Electronics - 07-12-2011, 08:57 AM #153
pretty sure, but i have to check when i get home, that i have those chichitec batteries at home..and they don't fit. too thick so the battery door just won't shut completely. i know for sure though that there is a mugen 1800 that fits as i use it all the time and i am pretty certain seidio's 1750 would fit perfectly also as i have always used theirs on other phones in the past.
- 07-12-2011, 09:35 AM #154
- 07-12-2011, 09:50 AM #155
there is improvement with the mugen - i'd probably get a few more hours with it.
- 07-12-2011, 10:45 PM #156
these are them right? yeah they don't fit. they don't allow the door to fully close. almost, but not completely.
- 07-13-2011, 07:43 AM #157
- 07-13-2011, 08:43 PM #158
- 07-13-2011, 09:21 PM #159
I am with you, although I usually make it a whole day, I am just cutting it too close, and sometimes not making it. However, I have spent many hours looking into this, and I think the answer is as simple as some people referring to usage (ex, light, moderate, heavy) in a much different way than others.
- 07-14-2011, 09:14 AM #160
- 07-14-2011, 05:42 PM #161
- 07-14-2011, 08:54 PM #162
- 07-16-2011, 03:18 PM #163
So I just bought on of these for $30 shipped. External battery/Charger
I figure I can keep it in my backpack and on those days where I think I might need it (like twice a week when I'm flying) I can use it to increase my up time. This way I can keep my slim, light Dinc2
Anyone else use an external battery? - 07-17-2011, 04:27 PM #164
I have to say that the best battery tip I've ever seen anywhere is to switch the phone from Global to CDMA mode. My battery easily lasts nearly two days with moderate usage after doing this, when it barely made it to one before. My "phone idle" is now at 10%.
- 07-17-2011, 10:42 PM #165
- 07-18-2011, 12:17 PM #166
- 08-04-2011, 08:17 PM #167
- 08-04-2011, 08:20 PM #168
- 08-05-2011, 10:05 AM #169
- 08-05-2011, 04:06 PM #170
It will not affect anything unless you are leaving the country and plan on roaming on GSM. In the US, there is no point on having it on global mode. If you plan to roam internationally, then just enable it before you leave. That was the first thing I did when I got my dinc2, so I don't know what the battery life would be with it on global, but I get great life with it in CDMA only mode. I average about 50-60 hours to 10% with moderate to heavy usage. Lighter usage, I hit 80 hours the other day to 10%, and that is with the screen on for over 5 hours.
- 08-05-2011, 04:08 PM #171
- 08-05-2011, 04:20 PM #172
For those interested I just got a free extended battery from Verizon after complaining like an abuse housewife.
For me, it all depends on my usage, some days I plug in at night with over 50% left, others I am dead before I get home from work, so as much as I hate to add the bulk, it's kinda needed. I will be putting it in tonight or tomorrow. Wanna find a time where I can turn the phone off and let it charge fully since that is what it recommends on the box. - 08-05-2011, 04:41 PM #173
- 08-05-2011, 06:06 PM #174
yes and all smartphone's battery life in comparison with a flip phone are horrific. you said yourself it depends on your usage. sometimes it last sometimes it doesn't.
the problem is you are coming into android with expectations. its a completely different platform. you can't hold it to the same standard. - 08-05-2011, 06:44 PM #175
i have no problem with your opinion of the battery life. i have a problem with you not sucking it up and BUYING an extended battery. instead you whined until they GAVE you one.
Reply
