Results 1 to 5 of 5
    Default Standard batteries for the Incredible 2
    I just received my Inc 2 and was wondering if any of the other HTC branded batteries from other phones fit the Inc 2. I had the Inc and the HTC Touch Pro 2 battery fit it perfectly and took it from 1300 mah to 1500 mah with the switch. Will the Touch Pro 2 battery fit the Inc 2 or is there another higher mah battery that will work?
    Thanks
  2. #2
    Default
    Ohhh interesting thought I'm curious to!
  3. #3
    ketchup's Avatar
    Posts
    Global Posts
    28 Global Posts
    Default
    I tried an extended battery from the DINC in my DINC2, contacts were reversed (on the other side). I bet this is the same with the standard batteries.
  4. #4
    LowFire's Avatar
    Posts
    ROM
    Stock
    Default
    1750mAh slim battery that fits like a standard:
  5. #5
    wfor1pilot's Avatar
    Posts
    Global Posts
    11 Global Posts
    Default Re: Standard batteries for the Incredible 2
    Has anyone actually tried this battery to see if it really does extend the life of the dinc 2? Has anyone found any other batteries that actually extend the life / I found a China company that did (but no longer makes it) that supposedly did work w/ the Dinc2
