Results 1 to 7 of 7
    Default GPS issues on Droid Inc2 or Google Sky Map problem?
    Is there a bug with the GPS on the DInc2?
    On the day the phone arrived, I opened Google Maps for the first time and noticed that it was a few miles off. This eventually corrected itself. Navigation worked just fine.
    Google Sky Map, though, is definitely not working on the DInc2. The DInc2 definitely doesn't know which way is north. hehehe I haven't tried out any other GPS utilities yet; so, I'm not sure if the problem is unique to Google Sky Map.
    Anyone else having any problem with GPS on the DInc2?
    Palm Treo 650 > Treo 700p > BB Curve 8330 > DInc (r) > Rezound (r)
    Transformer Pad Infinity (r CROMi-X)
  2. #2
    Default
    my google sky is working great on my dinc 2. Check to make sure your gps choices are correct.
    Default
    Quote Originally Posted by kat89447 View Post
    hmm...thanks for the feedback. the phone isn't here right now, but i know for sure that GPS is enabled in the location settings.
    i'll re-check.
  4. #4
    Default
    Does Google Sky actually get north right on your Inc 2? There have been multiple reports of Maps and Sky switching N/S when using the magnetometer. I'd like to know if it's a device specific problem, or a problem with all Inc 2s. One person has claimed that Verizon acknowledged it as a Inc 2 -wide problem.
    Default
    Quote Originally Posted by bdemarco View Post
    That sounds like the problem we were having. Time to email Verizon. I hope VZW & HTC are working on a fix.
  6. #6
    Default
    Same thing on my Inc 2... in google maps and in sky map, n/s is reversed.
    But my compass app works fine, and I did try recalibrating.
    Last week I called VZW and reported the problem; they called me back a day later and confirmed they found it on all Inc 2's.
    The rep said they would report the problem to HTC who would presumably fix it in a software update.
    Thanked by:
    TBolt
  7. #7
    Default
    is there a car mode for this phone? I could have swore I saw something while lurking around in the phone, but I can't find anything in the app drawer?
