Page 1 of 2 12 LastLast
Results 1 to 25 of 43
    Thumbs up Another Bolt to Dinc2 conversion -- Dinc2 is SO underrated!
    Had the bolt for a month and sent it back. The thing was just too darn big for me, the battery was miserable, and the 4G just isn't ready for prime time, although I know there's an update that will fix the handoff issue. Half the time my mobile network would go out and I would have nothing.
    I must say, 4G was fast though when it was working -- but I found that I really didn't use it much. I don't surf the web for hours or anything that needs the speed. All my other stuff syncs in the background so I really didn't care about how long it takes. And did I mention the battery? Man, that 4G sucks through that little battery with reckless abandon.
    So i switched to the Dinc2 and I can't say enough good things about it. It is the perfect size and weight. I don't know if it is the shape of the back or what because the dimensions are not all that different. It just feels so much better. So far the dinc2 battery seems to be great. Even much better than my original dinc, and far better than the bolt obviously.
    Everything about it is awesome. I just feel like too many people are jumping to the bolt like I did and not giving the dinc its due consideration. I wish more people would because this forum has far less attention than the bolt's do.
  2. #2
    Default
    Welcome! Glad you're on board. Many people don't realize that they don't need 4g. It's just marketing to the masses.
    Especially with the 5gb cap, you can exceed that limit pretty fast on 4g.
  3. #3
    Chrisy's Avatar
    Banned
    Posts
    Global Posts
    17,180 Global Posts
    Default
    Congratulates on your DInc 2! Glad you like it.
    (PS, above poster: we don't have a 5GB cap. We have unlimited data!)
  4. #4
    Bearly's Avatar
    Posts
    Global Posts
    231 Global Posts
    Default
    Can you estimate battery life for us? How many hours of what kind of usage are we talking about?
    Define please:
    minutes on calls
    sms/mms sent
    camera usage (# photos taken)
    GPS usage (if so, for how long were you using it, i.e. active navigation)
    BT usage
    browsing (and over wifi or 3G?)
    Thanks!
    I played with the Dinc2 in stores; very slick phone, very underrated.
  5. #5
    Default
    I dumped the Thunderbolt for the DINC2. The TB was too big and heavy for me. I came from the iPhone on AT&T so the size and speed was nice. I switched my wife from the iPhone to the DINC2 also and she is in heaven.
  6. #6
    ckelly33's Avatar
    Posts
    Global Posts
    132 Global Posts
    Default
    i too had the TB for a month. Couldn't be more happy to have a DINC2 again. There was a couple of weeks (or so) after I returned the TB that I had to go back to my DINC1 (DINC2 unreleased at that point) - I was happy to be in a DINC1 at that point too!
    I couldn't agree more with the OP.
  7. #7
    Default
    I really wanted the TB, but the battery life was a deal breaker for me. I am very happy with my choice..this phone is the perfect size and plenty fast. Most of the time I am on some sort of WIFI, so not having 4G isn't a big deal to me. I like the slimness, the weight, and over all look of the phone. The only issue I am having is with email app. I like having all my accounts under one roof but it doesn't seem to want to auto sync very well and often times not at all, but I am sure this is an issue that will eventually be fixed as I have read others with the same complaint.
  8. #8
    teddeli's Avatar
    Posts
    Global Posts
    177 Global Posts
    Default
    Quote Originally Posted by Bearly View Post
    Define please:
    minutes on calls
    sms/mms sent
    BT usage
    Thanks!
    While I can't show you the battery time I can tell you that after a week of use I find that I really can't tell much of a difference in the battery life on this phone compared to the Verizon extended battery I was using in my Dinc 1.
    Browsing both wifi and 3g, email, some nav but usually plugged into the car, very little video but no music.
    I also live on the South Shore of Long Island which doesn't have the best of signals but no call problems. If you live in a better signal area your battery life should be even better.
    My battery lasts all day
    This has to be the best all around phone I have owned
  9. #9
    thebizz's Avatar
    phone addict
    Posts
    Global Posts
    3,578 Global Posts
    ROM
    mean
    Default
    I feel this phone us under-rated also its great size weight speed and battery life have all been great. But most people see 4G or dualcore and dismiss this phone off top due to not having it. But this phone feels like it doesn't need it ill wait until they work out the bugs with 4g and optimize the software for dualcore but until then i have a great phone in the dinc2
    Rooted for life
  10. #10
    ckelly33's Avatar
    Posts
    Global Posts
    132 Global Posts
    Default
    Quote Originally Posted by jtwildman1 View Post
    Are the accounts you are having issues with by any chance POP accounts? Have you tried setting them up as IMAP?
  11. #11
    Default
    I hear so many great things about the dinc2. I agree about the size and weight but I don't know if I want this or the Droid X2. I'm really torn and the Revolution might also come out.
  12. #12
    swenpro's Avatar
    Posts
    Global Posts
    176 Global Posts
    Default
    Maybe wait til the end of this week to decide... as you mentioned, Charge and Revolution should be coming out any time, so comparisons can be made.
    I just handled these phones in store, and I much prefer the size of this DInc2 over the X2. 4.3" screen is a little overkill IMO.
  13. #13
    Default
    Can you find the X2 in stores? Because at my local verizon store they don't have them.
  14. #14
    Default
    Quote Originally Posted by saillling4life View Post
    No DX2 yet.Maybe by the end of the week but nothing is announced or official.
  15. #15
    Default
    Quote Originally Posted by Chrisy View Post
    Oh, there's still a cap. lol. Try downloading movies or torrents all day long. Don't be surprised when your connection goes ((poof)).
    Palm Treo 650 > Treo 700p > BB Curve 8330 > DInc (r) > Rezound (r)
    Transformer Pad Infinity (r CROMi-X)
  16. #16
    Default
    Kind of a shame that we don't see even 1 commercial on TV for the DInc2. The DInc2 is the Rodney Dangerfield of phones - "No respect . . . no respect at all."
    Looking forward to buying another one - for myself this time.
  17. #17
    Zombiepug's Avatar
    Zombie
    Posts
    Global Posts
    1,753 Global Posts
    ROM
    Stock
    Default
    he was referring to the Droid x he handled in store, as they are physically identical just beefed up specs.
  18. #18
    swenpro's Avatar
    Posts
    Global Posts
    176 Global Posts
    Default
    Quote Originally Posted by zombiepug View Post
    Thanks, zombiepug, that is what I meant.
    For all you DInc2 owners... I'm glad to hear you like the phone. But what about these supposed issues with signal? PhoneArena makes it sound like the DInc2's signal is really deplorable compared to other phones.
    I like a full-featured phone, but if the calling part of the phone is subpar, it may be a dealbreaker for me. Any comments?
  19. #19
    frankspin's Avatar
    Posts
    ROM
    CleanROM
    Default
    Quote Originally Posted by swenpro View Post
    I've had no issues with my signal and reception. I think someone on here touched on it possibly looking worse because they adjusted the algorithm for the signal display on the front of the phone. I think someone did a side by side of the DInc2 with their X and while the X showed 4 bars to the Dinc2's 1 they signal strength was the same.
  20. #20
    teddeli's Avatar
    Posts
    Global Posts
    177 Global Posts
    Default
    Its not the quality of the signal its the relationship of the signal bars to the actual signal. This was an issue with the Dinc 1 and seems to have continued with this phone. I have absolutely no problems making a call when there are no bars showing.
    Signal bars are not a good way to measure signal. They vary from model to model and vary between manufacturers. Those more bars ads from att were a load of garbage.
  21. #21
    thebizz's Avatar
    phone addict
    Posts
    Global Posts
    3,578 Global Posts
    ROM
    mean
    Default
    I've had no problems with signal on this phone it shows 1x were my d2 does and gets crap for service in house but no dropped calls like the d2 and fascinate
    Rooted for life
  22. #22
    Default
    I too returned Tbolt for Dinc2 and I agree that, by comparison, this is just the perfect size and weight and feels great in the hand. Feels more secure to hold too beyond just the comfort of it.
    There is a surprising lack of buzz for this phone, but I guess it's understandable. It's not top of the line and isn't rooted and doesn't have the developer support or buzz for that reason, so maybe those are the drivers.
    You would think this would be the phone for the masses though, given the currently incomplete 4G coverage and the current problems with it and the fact that reps actively trash the Tbolt to customers. What else are they going to push right now, the X? You'd think they'd be pushing this one hard as the steady and dependable alternative that would be the easiest, please the most people, and generate the fewest problems for them. I don't care about the lack of attention from an emotional standpoint but would like to see more attention given just because there would be more people to compare notes with and get help from and more special goodies and fixes from developers. We'll just have to roll up our sleeves and become the change we want to see, siblings!
    To the person asking about call quality, I've had no issues. Right now I'm at home and am connected over femtocell (Vz network extender) so I show four bars constantly. If I were not on femtocell, I'd have 0 to 1 bars most times here in my fringe coverage area. But I haven't had problems when I drive into areas with better signal for whatever anecdotal value that may offer.
  23. #23
    Adrynalyne's Avatar
    Account Deactivated
    Posts
    Global Posts
    1,478 Global Posts
    Default
    Battery sucks on the stock TB.
    Luckily, we have roms and kernels to entirely alleviate that.
    There is a screencap in one of my threads that has a 41 hour battery time, unplugged. 14 hours of those were awake time., and the user is on 4G.
  24. #24
    Default
    Quote Originally Posted by Adrynalyne View Post
    Here's what I don't get. If you guys can very quickly come up with these roms and kernels that completely remove everybody's biggest gripe with this phone and other recent HTC phones, what the hell are they doing in the programming department over at HTC? Why is it that you guys are able to tweak this and tweak that in your spare time and arrive at something so much better than what these hardcore guys can get done 9-5 when they get paid big bucks for it? If the hardware and software are capable of getting the kind of life you guys can squeeze out of this battery and others, why can't those guys make it work? You'd think after all the complaints about the battery life of things like the EVO and Incredible, they'd have taken particular care to optimize this one and any other phone they put out these days. Why don't they?
    The non romming mortal masses use this phone for a week and say forget it and take it back. HTC could beat that. They could prevent that. But nope. Is there some advantage to doing it their way? Are you guys shaving off things that they think are features that people want, and that's what burns up all the juice? Is Sense just poorly made and heavy and hungry? Or are they just sloppy? Or just not very good? Or weighed down by pressure to save money by reusing code or something else bureaucratic like that? What?
  25. #25
    Default
    I'd love to hear the answers to Astrodroid's questions, too.
