Does anyone have any luck removing the bloatware? please help and tell me how. i tried app task killer and it appears that they are all hidden apps
Temp root then use Titanium backup or Bloat Freeze
Check here for instructions: http://forum.androidcentral.com/incredible-2-rooting-roms-hacks/82423-how-temp-root-dinc2.html
Have you done this? I have seen people on XDA report issues with Bluetooth and other features not working after temp root. I know root is always a risk, just curious if those are common issues or isolated.
You could also download Launcher Pro from the Market and hide the unwanted bloatwares from the application drawer.
Shahr
I have heard of Bluetooth issues as well, I haven't experienced any myself. I was listening to music the other day fine....I don't remember if I had the temp root in or not though.
Regardless, if you have an issue while temp rooted, just reboot to fix, using Bloat Freez or Titanium keeps the VZW crapware gone. I have done many reboots and none of it is to be seen on my phone anywhere
