DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 3 of 3
    Default Please Help: Regarding: Notification Sounds
    Hi Everyone:
    This is my first smart phone and i decided on the droid incredible 2..
    I seem to be having an issue, hopefully one of you in the know can help
    Im assuming when you get an email. or a facebook message to your phone
    that a notification sound is supposed to ring, because there is a setting to set those tones..
    which i have done.
    However, whenever receiving an email message or a facebook message, the message comes through but the notification sound does not ring... Is anyone having a similar issue? Is this is a defect? Have i not set something correctly in the settings? Can someone help? It would much appreciated
    Thanks
  2. #2
    Default
    Go into Settings > Sound > Volume and check the box "Use incoming call volume for notifications" I had the same issue but this fixed it. You can also download a app called "Sound Manager" from the market place. It's a free app. Hope this helps
    Default
    thanks for your help:
    i figured it out
    you actually have to hit the menu button
    while youre in the mail app and facebook app
    and there is a setting in each individual app (when hitting the menu key) for notification sounds
    hopes this helps anyone else who is as clutzy as me LOL
