Results 1 to 6 of 6
    kmknite8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Droid Incredible 4G: phone won't turn on after update
    Hello. My phone did an update and when it went to reboot it shut off and now wont turn on. No light's no nothing... even when plugged in it does nothing. Removed battery and tried resetting (held power and vol down), removed sd also. Its like its dead. Any info on this? Thank you
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,718 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Droid Incredible 4G: phone won't turn on after update
    Welcome to Android Central! That doesn't sound good. How long did you try holding the Power button down for? Sometimes it takes upwards of 10-15 seconds.
    kmknite8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    A good minute... verizon basicly said its dead..... and not from the update.. it was a coincidence he said...
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    77,718 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Are you able to get a replacement under warranty, or are you due for an upgrade?
  5. #5
    revsimba's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    pls my htc incredible 4g lte just shut down, and i can't restart it again
  6. #6
    Rykk James's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Remove the battery, wait ten seconds, put the battery back in and hold the power button for five seconds.
  1. Turn off My Magazine / Flipboard
    By Bren Bren1 in forum Samsung Galaxy Note 3
    Last Post: 02-03-2016, 01:03 PM
  2. Note 3 dead, not charging and won't turn on
    By chloeshotmom in forum Samsung Galaxy Note 3
    Last Post: 07-13-2015, 08:23 AM
  3. Anyone interested in the Framily Plan on Sprint?
    By Mark Zagotti in forum Verizon
    Last Post: 01-25-2014, 10:39 PM
  4. Replies: 6
    Last Post: 01-23-2014, 11:20 PM
  5. Phone Contact not syncing to Outlook via Kies
    By empeyg in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-23-2014, 07:13 PM
