Results 1 to 6 of 6
    Question MicroSD Card
    I only have one very simple question about this phone and I can't seem to get it answered anywhere. Maybe somebody on here knows what's up.
    Does the MicroSD Card slot expand to 16gb or 32gb? I've read it both ways and I don't know who to believe. The Verizon website says 16gb. The manual that was leaked doesn't say anything about the expandable size. I emailed HTC and they said to email Verizon. I emailed Verizon and they said they can't speak about the phone since it isn't released. Keep in mind, VZW emailed me back today. The phone is finalized I don't understand why HTC or VZW can't simply answer the question. Anyways, enough ranting. Anyone know for sure and what's your source? I'm trying to get rid of my 32gb iPod Touch but if this thing only expands to 16 gigs then I'll have to keep it as I have the 32gb almost full of music.
    Thanks!
    Phil
  2. #2
    Default
    i've heard android 2.1 doesn't play nice with 32gb cards...
  3. #3
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default
    Here is your answer.
    Default
    Thanks Cory, I read that article the other day. But that's dealing with software. Isn't it a hardware issue as well if a phone can use a 16gb or 32gb card? I'm wondering if that hardware of the Incredible supports 32gb.
  5. #5
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default
    Yes, it can support a 32GB card. You just need to format it first before you stick it into the Incredible, as the Incredible won't be able to do that. The article was updated earlier to clarify that point. Good question though.
  6. #6
    Phil Nickinson's Avatar
    Android Central Editor in Chief
    Posts
    Global Posts
    3,435 Global Posts
    Default
    Exactly. And do note that the phone DOES NOT come with a microSD card. It does, however, have 6GB of space on board.
    Quote Originally Posted by Cory Streater View Post
